Spider Cracks in the Trunk. - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 08-17-2007, 05:38 PM Thread Starter
Trainertim77's Avatar
Year: 1999, 2014
Model: GL1500, GL1800
Hi everyone,
I just purchased a fairly new 1999 GL 1500. It only has 20K miles on it and is in excellant condition. However I have notice there are cracks on the trunk where the luggage rack is connected. They are like spider cracks...I suspect from flag holders (just a guess) anyways how can I stop those cracks for getting worse. Will a fiberglass repair kit from the inside stop them?
May we never forget our Fallen Hero's nor those special Angels among us.
Tim
GL1500
1SG Iowa Army National Guard
Iowa Patriot Guard
Trainertim77 is offline
post #2 of 2 (permalink) Old 08-17-2007, 09:12 PM
Fiberglass (polyester resin) and epoxy really doesn't bond all that well to ABS which is what the trunk is made of. You can use ABS cement, it's the black goop sold in hardware store plumbing sections for gluing ABS pipe. Not the PVC/ABS cement, but black ABS only cement. You can lay up a layer or two of fiber glass cloth with the stuff. Don't put a lot of heavy coats on at one time, a thin coat allowed to dry hard before the next one works best. The stuff does take a bit of time to fully harden but will result in a chemical weld to the original plastic. You can't pry it off like you can with fiberglass resin and epoxies. Just clean any paint off the underside of the trunk lid in the vicinity of the repair.
If you have a trunk rack it should have a good sized star washer (sold by online bike vendors) under the legs of the rack, a rubber washer under that and a rubber washer and fender washer underneath the trunk lid. This will help spread the load without causing as much of a localized stress rise.
Think you got a spider problem ?? picasso Fun Forum 0 02-08-2011 06:42 AM
1100 trunk cracks Wilcoy02 Goldwing Technical Forum 4 10-06-2010 08:08 PM
living spider kah92340 Fun Forum 5 03-03-2009 12:00 AM
Mum there's a Spider..... Swaggerman Fun Forum 8 02-10-2008 06:49 PM
Spider vehical TarHeeLBiker Miscellaneous Forum 0 10-10-2007 08:12 PM
