Anti-dive - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 10-09-2007, 07:55 PM Thread Starter
Does disabling the anti-dive improve the ride quality? If so, how does one go about disabling it on a 2000 SE? I am less than happy with the ride and handling of my bike.
Art Eadie
Ladson,SC
2000 GL1500 SE
Coronado Blue (I think)
Art708 is offline
post #2 of 10 (permalink) Old 10-09-2007, 08:09 PM
fatwing chris's Avatar
I doubt that it will change your ride but it will definitely affect the handling for the worse. Have you tried changing the suspension settings or the tire pressures.How many miles are on the bike?Maybe it's due for new springs or a fork oil change.A lot of the 1500 guys on here replace their shocks and springs with Progressive's.
Fatwing Chris
Darkside #1602
Gone Double Dark with a BT45
fatwing chris is offline
post #3 of 10 (permalink) Old 10-09-2007, 08:18 PM
beachbuddy0253's Avatar
i agree, progressive springs and shocks are the way to go.
beachbuddy0253 is offline
post #4 of 10 (permalink) Old 10-09-2007, 08:36 PM
dan filipi's Avatar
Model: 1983 GL 1100 I
Tell us what you dont like about the ride then it will be easier to make suggestions.
dan filipi is offline
post #5 of 10 (permalink) Old 10-10-2007, 09:37 PM
Dan's right, kinda hard to help, is the suspension too soft? Could be low oil. Too hard? Could be too high air pressure or too much oil, might have Progressive springs which will make it much firmer than stock.
The anti-dive doesn't do anything until you use the brakes. Full anti-dive on both sides of the fork doesn't come into play unless you use both the brake pedal and the handlebar lever. So the anti diveshouldn't be affecting your ride quality.
post #6 of 10 (permalink) Old 10-11-2007, 01:47 AM
mikeatrain's Avatar
Year: 86
Make: GL1200
Model: Interstate
What is the air pressure front and rear?? Many here recommend a higher air pressure than stated in the manual. 41/41psi front and rear - that made a great improvement on my 83interstate.
This is kind of like throwing darts while blindfolded. A little more info would help.
Mikeatrain
1983 GL1100 Interstate (SOLD)
Keeps on going and going and going
and still going under new owner
Then I found a 86 GL1200I to cheap to pass up.
mikeatrain is offline
post #7 of 10 (permalink) Old 10-11-2007, 05:51 AM Thread Starter
What I don't like about it is.... it rides too hard. The front air pressure is only about 2#, the rear is about 35#. I'm thinking that maybe the front forks need to be rebuilt. Hopefully this will become a moot subject as someone is interested in buying the bike.....fingers crossed. Then I can go back to the Valkyrie which I have come to realize that I like better than the GW.
Art Eadie
Ladson,SC
2000 GL1500 SE
Art708 is offline
post #8 of 10 (permalink) Old 10-11-2007, 06:01 AM
Monkey with a Football
Rudy's Avatar
I know a member in your area that might be interested in it if your sale falls through.
I don't use any pressure in the forks at all. Just progressives, good seals and bushings and fresh oil of the desired weight.
It is nice that you have ridden the valk and the wing to be able to make the change from experience rather than hype. We just had a member go the other way so it's obviously different strokes for different strokes when it comes to bikes.
Rudy
wasn't too much fun”
Rudy is offline
post #9 of 10 (permalink) Old 10-11-2007, 06:26 AM Thread Starter
Rudy, I'll post here if this guy doesn't buy it. Maybe something magical will happen and I'll end up keeping it but I doubt it. It's funny that my observations are totally different from the other member who traded his Valk. I find that the Valk was a LOT more stable than the GW. The GW gets blown around by trucks on the highway MUCH more than the Valk did. I'm thinking that it's all the plastic catching the wind. ?And the handling.....man, there's no comparison in cornering...and power. Anyway, I don't want to alienate any GW riders, these are just MY opinions and not meant to belittle the GW. I guess that's why they make Fords and Chevys.....or Goldwings and Valkyries, huh?
Art Eadie
Ladson,SC
2000 GL1500 SE
Art708 is offline
post #10 of 10 (permalink) Old 10-11-2007, 08:01 AM
Guru
Hatchetman's Avatar
What happens to fork oil that it requires changing? When refilling your tubes, What is the most accurate form of measurement? Thanks!
Hatchetman is offline
GL1800 Anti Dive west5wing New Members Introduction Forum 17 06-18-2012 02:01 AM
GL1800 Anti Dive west5wing Goldwing Technical Forum 1 06-11-2012 12:28 PM
GL1800 Anti Dive Unit (Brake servo-pressure sensing anti dive) Paul Hopewell Feedback for Hondas Goldwing Team 3 10-10-2011 02:05 AM
how do you know if your anti dive valves gone? pinkpork Goldwing Technical Forum 24 10-30-2007 02:49 PM
Anti-dive tntriker Goldwing Technical Forum 20 10-06-2006 02:31 PM
