Break pedal doesn't go up. Bad spring? 83 Wing. - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 10-23-2007, 09:20 PM Thread Starter
Thanks.
76, 83, 84I,84A, 86 SEi Wings are gone, now 75, 84A
I have to stop buying dead old Wings...
ignition switch for $8, solenoid for $10, fuel pump for $30 still work fine!
newbiker is offline
post #2 of 10 (permalink) Old 10-23-2007, 09:22 PM
teacher's Avatar
Year: 1983
Thanks for..................................
~teacher~~~
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #3 of 10 (permalink) Old 10-23-2007, 09:24 PM
creekwalker's Avatar
Send a message via MSN to creekwalker
E.S.P
James "creekwalker" McCauley
1993 GL1500 SE 2 tone blue
3 weeks of winter......gotta love the south
creekwalker is offline
post #4 of 10 (permalink) Old 10-23-2007, 09:26 PM
retiredintime's Avatar
Oil pedal...
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #5 of 10 (permalink) Old 10-23-2007, 09:29 PM
teacher's Avatar
Year: 1983
I'm guessing you are thanking someone for answer your question in the Title of your post.
I could be the spring has come loose from one of two points. Or the spring is sprung. Or the inside is rusted and needs to be taken off and cleaned. If this is a new purchase and the bike has been setting for a while my bet is on the rusted thing.
~teacher~~~
~Butch~~~
teacher is offline
post #6 of 10 (permalink) Old 10-23-2007, 09:33 PM
Guru
Hatchetman's Avatar
mine was like that when I bought it. i pressure washed the joint where it hinges and worked it with the brake assy un hooked. after a few minutes it free'd up and I lubed it. They get a build up of road slop and get sticky from time to time!!
Hatchetman is offline
post #7 of 10 (permalink) Old 10-23-2007, 09:46 PM
mikeatrain's Avatar
Year: 86
Make: GL1200
Model: Interstate
It could be a bad spring, if your asking how to get the pedal to come up. Use penetrating oil on brake pedal next to frame and inside on the post also. Work pedal and apply more oil to both placesand keep working it. Let it sit over night and apply more oil and work it some more. If the pedal is stiff it should free up after working it. If the spring is bad you should be able to see or feel that.
After I got mine free I apply a generous drop of used oil every time I change the oil now. Just dip my finger in the old oil and put a drop both inside and next to the frame. It's working great now.
Mikeatrain
1983 GL1100 Interstate (SOLD)
Keeps on going and going and going
and still going under new owner
Then I found a 86 GL1200I to cheap to pass up.
mikeatrain is offline
post #8 of 10 (permalink) Old 10-23-2007, 11:39 PM
S Clark's Avatar
Mine did the same thing. Everytime it would rain, it would rust and tighten up. Finally I got tired of working spray oil into it and installed a grease fitting. No more problems
Scott
82 standard with Vetter extras
84 Aspencade
S Clark is offline
post #9 of 10 (permalink) Old 10-24-2007, 04:45 AM
teacher's Avatar
Year: 1983
WOW! Great idea S Clark.
~teacher~~~
~Butch~~~
teacher is offline
post #10 of 10 (permalink) Old 10-24-2007, 09:13 PM
byronicman's Avatar
I had my pipes off, and took the lever off the shaft, cleaned it up, greased,
and re-assembled. figure that ought last for years..
Previous bikes CA110 CL90 SS125 Cb450 dt360 cb450 cb350 cb500
current cb500 (sleeping) 82GL500I (my baby) and
of course 83 Aspencade (almost there!)
(about 65,000 miles in all)
byronicman is offline
gl1100 break pedal tybme Goldwing Technical Forum 4 03-23-2011 11:59 AM
Rear break pedal rider 76 Goldwing Technical Forum 2 07-15-2010 04:34 PM
Rear break pedal, GL1500 scoot scoot Goldwing Technical Forum 1 03-06-2010 09:41 PM
Adjust Rear Break Pedal rak69 General Motorcycle Discussion Forum 4 05-02-2008 10:48 AM
Rear break pedal distance toy4rick Goldwing Technical Forum 3 04-24-2006 07:09 PM
