84 Int. Which coil works for which cylinder? Firing order? - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 11-23-2007, 03:03 PM Thread Starter
Thanks. Mine: left coil for 2 rear cylinders, right for 2 front ones.
I have 3 manuals and cannot find it. Found it for 85 L but it could be different.
Here is odd problem: resistance between wires is OK about 23KOm. +connector attached to each coil and has 12V. I touch another connector with grounded wire but there is no spark...
I have found firing order: 1-3-2-4. That means coils have to work for 1,2 and another one for 3,4.
Now I need wire colors to coils.
76, 83, 84I,84A, 86 SEi Wings are gone, now 75, 84A
I have to stop buying dead old Wings...
ignition switch for $8, solenoid for $10, fuel pump for $30 still work fine!
newbiker is offline
post #2 of 4 (permalink) Old 11-24-2007, 07:05 PM
Newbiker, I don't have the info you want but Honda is good about using the same wire colors for the same things on different models and years so if you have info for an 85 it should work.
David
post #3 of 4 (permalink) Old 11-29-2007, 01:05 PM
andy1800's Avatar
Model: 2008 GL1800, 16k miles
If you download the workshop manual from the thread at the top of the tech forum, you will be able to get the colours from the wiring diagram.
andy1800 is offline
post #4 of 4 (permalink) Old 11-29-2007, 02:50 PM
RB
RB's Avatar
Send a message via AIM to RB
I have mine out and in my hands from an 82 interstate but i think it's the same set up for 83.
The 1/2 coil has a black /yellow and a black braided wire hooked to the right side tab. The blk/yl goes to the right tab on the other 3/4 coil and the black braided goes to the white baluster thing on the right side. The left tab on 1/2 coil has a yellow wire that goes to the white 4 pin connector. The 3/4 coil has blk/yl wire from the 1/2 coil on the right side tab and the left side tab has a blue wire going to the 4 pin connector.
The left side of the baluster has the black braided wire coming out of it and going to the 4 pin connector.
If you hold the four pin with the locking loop up ..the top right pin is the blue wire, the top left is the black braided from the baluster and the bottom left is the yellow the bottom right is open.
Hope that all makes sense.
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
GL1500 Firing order Doubleeyes Goldwing Technical Forum 3 03-19-2012 06:22 AM
Firing Order- GL 1000 moose4jesus Goldwing Technical Forum 6 09-14-2011 06:39 AM
1500 firing order viking2476 Goldwing Technical Forum 8 06-30-2011 02:31 AM
GL12000I FIRING ORDER luckyseven Goldwing Technical Forum 5 10-26-2009 07:08 PM
firing order and coils meathead69692 Goldwing Technical Forum 11 02-28-2007 04:08 AM
