1200 goldwing - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 12-09-2007, 09:09 PM Thread Starter
basstracker's Avatar
The bike sat for about 6 weeks , when i started it up it was missing. I checked it out an # 1 is missing. The plug is firing fine, The compresion is 150 .how can i tell if its getting gas to that cyl.
basstracker is offline
post #2 of 14 (permalink) Old 12-09-2007, 09:40 PM
Is this an SEI or carburated model? If it's injected put the tip of a screwdriver on the injector for the missing cylinder, hold the handle to your ear and listen for the click, compare it to another one for the same sound. If it doesn't click or sounds different
the injector may be stuck or clogged. If it has carbs open the drain screw in the bottom of the bowl and see if gas drains out. The float valve could be stuck if it is dry or the jets plugged if it has gas in the bowl. Let us know what you find.
David
post #3 of 14 (permalink) Old 12-09-2007, 09:48 PM
If it was running good when you last drove it, it may have gunked up a little bit just sitting there.
Might try Sea Foam and see if it will clear the problem. Cheap to try.
post #4 of 14 (permalink) Old 12-09-2007, 11:17 PM
Senior Guru
Goldwinger1984's Avatar
Does the missing go away when you rev the bike up a bit? If so the slow speed jets are most likely dirty.
Vic
Goldwinger1984 is offline
post #5 of 14 (permalink) Old 12-10-2007, 10:36 AM
Hawker22's Avatar
If the plug is staying dry, it is a good indication that no fuel is getting there.
Hawker22(Ken)
Per Ardua Ad Astra
1997 GL1500SE--White Cloud
2001 GL1800----Blue Yonder
Hawker22 is offline
post #6 of 14 (permalink) Old 12-11-2007, 08:27 PM Thread Starter
Hello everone, thanks for the replys. I finely got back on my bike two days later, fired her up an no miss, # 1 cly is doing fine. i put everthing back on an rode for a while an its o k.ive been having troublestarting it when it gets hot, it bearly turns over.the battery shows full charge,but when i hook up the batt charger an put it on 6 amp it will crank. is it a bad batt or starter?
post #7 of 14 (permalink) Old 12-11-2007, 08:31 PM
freonrick's Avatar
clean the battery cables even if they look good hooked up.
freonrick is offline
post #8 of 14 (permalink) Old 12-11-2007, 08:49 PM
teacher's Avatar
Year: 1983
My bet is on the starter brushes......................................
~teacher~~~
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #9 of 14 (permalink) Old 12-12-2007, 01:14 AM
AirCutoff's Avatar
teacher wrote:
basstracker wrote:
*is it a bad batt or starter?****
~teacher~~~
I'm with that too. let us know what it actually is?
Past bikes in no particular order -
65 Yamaha 80
67 Yamaha 305 Scrambler
71 & 75 HD Sportster
75 HD FLH
72 Suzuki T500
74 Suzuki GT550
77 Suzuki GS750
72 & 81 BMW R75/5, R100RT
83 Yamaha XT200
Current bike:
81 Honda GL1100
AirCutoff is offline
post #10 of 14 (permalink) Old 12-12-2007, 02:03 AM
Old Broad
fysty-1's Avatar
Year: 1995
Make: Yamaha Virago
Model: 1985 GL1200 I w/LTD body(SOLD :( )
Send a message via Skype™ to fysty-1
~teacher~~~
I agree with teach. Mind did the same thing and I thought it was battery but found out it was starter. No problems since. Oh welcome to the site
Angela, aka fysty-1(R) & Dani(L), S.Surrey, B.C.
1985 Gold Wing GL1200 I(SOLD Apr/2012)
No matter how blue it may get, there is always a rainbow in the sky.
Blue is not the fastest color, but it is the prettiest.
(women only)
fysty-1 is offline
goldwing 86 1200 semper7 Goldwing Technical Forum 9 11-03-2011 11:09 AM
85 1200 goldwing mort952 Goldwing Technical Forum 22 04-24-2011 09:35 PM
1200 goldwing sandman jim General Motorcycle Discussion Forum 30 04-26-2009 09:40 PM
1200 goldwing gumby Goldwing Technical Forum 2 03-25-2008 04:35 PM
1200 goldwing hp? carson General Motorcycle Discussion Forum 6 10-12-2006 07:59 AM
