side panel male pins?? - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 01-18-2008, 01:44 AM Thread Starter
Psalmist's Avatar
Send a message via Yahoo to Psalmist
Is there a sticky on how to make a male part to fit my side panel (battery cover)? My lower left one was gone when I got the bike. With the SE, I can raise the passenger boards for some safety. PO put chrome plates on side panel with small bolts to atatch it to panel.
I'm hoping someone comes along with a clothspin or similar idea to JB weld it to the inside panel. thanks
dino
Dino Hutchings
Fort Smith, AR
1999 pearl silver SE
Still trying to be pleasing before Jesus
Come to Arkansas and ride year round!
Psalmist is offline
post #2 of 12 (permalink) Old 01-18-2008, 01:52 AM
hparsons's Avatar
I used some of this:
http://www.amazingmoldputty.com/
Basically, it's a putty that dries into a rubbery mold. You can then pour two-part epoxy into it to creat a new post.
To tell the truth, it made the post fine for me, but I haven't gotten it attached yet. Probably soon, but it did make the post very nicely.
hparsons is offline
post #3 of 12 (permalink) Old 01-18-2008, 02:04 AM
mikeatrain's Avatar
Year: 86
Make: GL1200
Model: Interstate
I've never used this kit but it should work for you to rebuild/repair the missing peg.
http://plastex.home.att.net/
I would not use JB weld, ABS plumbers cement works much better (it is used to weld ABS plastic pipe together). I have had very good results with the ABS cement used to repair cracked lowers and welded the lower tab back on the lower fairingcowl. However I had all the pieces and it was just a matter of welding them back together. It sounds like you may be missing the peg and the kit above should help you fabricate the pieces you need.
Good luck!
Mikeatrain
1983 GL1100 Interstate (SOLD)
Keeps on going and going and going
and still going under new owner
Then I found a 86 GL1200I to cheap to pass up.
mikeatrain is offline
post #4 of 12 (permalink) Old 01-18-2008, 08:41 AM
Both side panels on my 91 had missing pegs and the previous owner used samll bolts to hold them on. On my battery cover, the lower left peg, I used an allen head bolt and rounded the head over so it would slip in and out of the rubber gromet and used an acorn nut on the outside. I haven't done anything to the right side because of the rounded end of the cover. One of these days an idea will come to me.
Hard to come up with one when it's 20 degrees outside and I can't ride!
ddrumman2004 is offline
post #5 of 12 (permalink) Old 01-18-2008, 09:20 AM Thread Starter
Psalmist's Avatar
Thanks to all for the input. I guess I need to find these things online (rubber, epoxy) unless WalMart has them
BTW, I rode in 17 degrees today. We get cold weather but hardly ever snow. With the SE's added foot vent and Tulsa's hot shoe, my feet and lower legs stayed warm. That is my new record. I can only count it if I travel 60 mph for 10 seconds. Just my fingertips got numb. Those pizza's do pay off sometimes
Have a good one all! Stay warm.
dino
Dino Hutchings
Fort Smith, AR
Psalmist is offline
post #6 of 12 (permalink) Old 01-18-2008, 09:55 AM
I can't ride because I can't get my Wing out. Where I park, I have to ride off of my parking area and into my yard which is soft from all the rain we have had.
I need a better place to park!
post #7 of 12 (permalink) Old 01-18-2008, 04:15 PM
hparsons's Avatar
I picked up the stuff I used (the rubber mold and the casting epoxy) at Hobby Lobby.
hparsons is offline
post #8 of 12 (permalink) Old 01-19-2008, 02:14 AM Thread Starter
Psalmist's Avatar
WAY COOL!! We actually have on here!!
Thanks! Did you make a mold in halfs then tape together? How will you glue it to the panel?
dino
Dino Hutchings
Fort Smith, AR
Psalmist is offline
post #9 of 12 (permalink) Old 01-19-2008, 04:35 AM
hparsons's Avatar
I'm assuming you're addressing this one to me.
Didn't make it in halves. I just put a big blob of the putty around one of the posts that's still there. As I said, the mold is rubbery, so it just peeled off. Mixed the two part casting epoxy, and poured it in. Out came an almost exact replica of the exising post. Like I said, I haven't glued it on yet, but soon I'm sure.
hparsons is offline
post #10 of 12 (permalink) Old 01-19-2008, 09:06 AM
WingedNut's Avatar
I used some Devcon (brand name) two part epoxy plastic welder I bought at WalMart (I affectionately call it 'Wallow World') to fasten on a broken off tab. Seems plenty strong but being winter in North Dakota and -20 degrees this AM I haven't given it a road test.
I also used the epoxy to fill in a couple of holes the PO drilled in the right fairing pocket cover and also the ignition switch cover plate. Worked great except I've onlly found it in a cream color so had to use black magic marker to hide the evidence. Actually looks good except under close examination.
There\'s no such thing as sanity and that\'s the sanest fact - Dire Straits
Past:
Honda 150 Dream
1947 Harley (stolen before ridden)
Honda 250 Scrambler
Honda 450 Scrambler
1980 Honda CB650
Present:
95 GL1500A (Pearl Sierra Green)
WingedNut is offline
GL1500: How2, Hack Repair for Broken Pins to Side Panel ALEX BERECZKY Goldwing Technical Forum 4 03-16-2012 10:13 AM
Side Cover Replacement Pins KAHUNAH General Motorcycle Discussion Forum 8 07-26-2011 08:25 AM
Wanted right side panel Gwinginit For Sale/Wanted Forum 1 11-20-2010 12:42 AM
GL1500 side cover mounting pins replace greggchill Goldwing Technical Forum 4 08-25-2009 08:50 AM
side panel saioro Goldwing Technical Forum 4 10-24-2008 01:22 PM
