Slave Cyl. Rebuild - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 01-21-2008, 09:58 AM Thread Starter
gaz1200's Avatar
Hi everyone, I was wondering if anyone has tips for rebuilding my slave cyl. I am almost positive this is the problem, I have fluid leaking out of the back where the slave is and after a few weeks or a hundred miles I am out of fluid. I have the clymer manual and the rebuild kit for the slave. Any advice appreciated. Thanks, David
I am not Dave in the ditch.
Currently Own: 1986 Goldwing 1200 Interstate
Past bikes I have owned: 1988 Honda Shadow VT800C, 1984 Suzuki GS 350A.
gaz1200 is offline
post #2 of 6 (permalink) Old 01-21-2008, 10:17 AM
BryanMD's Avatar
Hello David.
The rebuild procedure is basically the same as for a brake caliper and the detail should be in your service manual. If you have a more specific question...
You can\'t solve you\'re problems with the same level of thinking that created the problems.-Albert Einstein
The Pace (read it!)
BryanMD is offline
post #3 of 6 (permalink) Old 01-21-2008, 01:07 PM
Keystone742's Avatar
Year: 1984
Model: Gl1200I
It's a simple, straight forward job. The most difficult part will be in bleeding thething when your finished. I've found that using the syringe method works the best for me. While you at it, might as well inspect the brake lines for wear.
1984 1200I Candy Cobalt Blue over Bright Silver Metallic w/ Black & Silver Marbling. Poorboy alternator. Progressive springs and a comfy gel seat.
Keystone742 is offline
post #4 of 6 (permalink) Old 01-21-2008, 02:49 PM
beachbuddy0253's Avatar
i replaced the slave cyclinder on my 1200 and it was pretty easy. when you bleed it make sure you get fluid out of the bleeder then stop, bleed the banjo nut and then bleed the whole system again, it took me about ten minutes to bleed mine that way.
beachbuddy0253 is offline
post #5 of 6 (permalink) Old 01-21-2008, 03:13 PM
EDDIE W's Avatar
as already been said, the job is easy, dont forget to cover your plastics against spillage, and put the cap over your m/c so it doesnt spurt out over you when pulling the lever
GSVH
\'88 GL1500
EDDIE W is offline
post #6 of 6 (permalink) Old 02-10-2008, 05:48 PM
Hi, new to the forums, but I'm having the same problem. Do I have to worry about the fluid I lost behind the clutch slave?
I had a "friend" borrow the bike and put dot3 in the system and I've rebuilt the master and replaced the lines, but still waiting on the slave kit. Just wondering if anyone knows if I've got to go any further in.
forensicbiker is offline
99' 1500 SE Clutch Slave Rebuild DOC1500 Goldwing Technical Forum 21 05-22-2012 02:58 PM
GL1200, Clutch Master Or Slave Cyl !!! Which One Is Bad? CBX n GL man Goldwing Technical Forum 14 01-29-2012 07:53 AM
Slave cylinder Rebuild GL1500 awall4400 Goldwing Technical Forum 1 10-21-2009 05:26 AM
slave cyl reseal?--89--1500 JWB Goldwing Technical Forum 2 12-08-2007 07:09 AM
Bleeding 1500 slave cyl Wayne C. Goldwing Technical Forum 2 08-30-2006 11:58 AM
