1986 GL1200 SEI Pulse Coils / Pulse Generators - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 02-24-2008, 09:18 PM Thread Starter
I have had a problem that I posted previously about the bike losing power when hot. I checked the heat problem and I am confident that the cooling system is fine. Using a pistol grip thermometer, I found that after warm up, radiator temperature went from about 180 F at the inlet to 110-115 at the outlet. Seems more than adequate.
The other thing that people suggested was the pulse coils, but I have found that very confusing, so I need a little help to sort out the truth.
Pulse generator and pulse coils seem to be used interchangeably for this part, so I'll take that as true.
One forum said that the pulse generator is the same unit as the crankshift position sensor. Is that true? I replaced the crankshift position sensor (located under the timing belt cover) a couple of years ago and I'd be surprised if it's gone bad again, so I probably need to look for something else.
The shop I go to ordered a part (Honda OEM 36142-mg9-951), which is labeled a pulse generator. The parts schematic is attached to this post. This, apparently, is mounted on the back of the engine based on the direction shown to the front. However, I can locate no such assembly on the rear of the engine. Both manuals I have consulted (Haynes and Clymer) say that Honda moved the pulse generator to the front under the timing belt cover beginning with the 1985 model year. The Clymer manual shows the attached schematic, but labels it the camshaft position sensor for the 1984 model. 1985-87 are shown under the timing belt cover on either side of the crankshaft.
But several online parts fiche sets do show this part for the 1986 GL1200 SEI, with the attached schematic as the location.
Can anyone shed light on the actual location of the pulse generators on the 1986 GL1200 SEI? Are they the same as the crankshaft position sensor?
This is getting more desparate as the problem has progressed to the point that the like now runs erratically even before it is hot, and craps out completely much sooner.
Thanks!
[img]file:///C:/DOCUME%7E1/ERICTU%7E1/LOCALS%7E1/Temp/moz-screenshot-5.jpg[/img]
EricTurner is offline
post #2 of 4 (permalink) Old 02-24-2008, 09:43 PM
TNroadrider's Avatar
Eric, I also had an '86 SEI fuel injected bike so I hopeI can help with this info. The NS (Crank sensor which is also erronously referred to as a pulse generator) is located under the front cover behind the timing belt. The actual Pulse generator is located on the back of the head on the right side of the bike (as in your sitting position) it is located about where your right foot would touch the back of the cylinder head, you will notice a cover that resembles the one in your parts sketch.
When you replaced your crank (NS) sensor did you replace it with a new one or a used one? It may seem odd that one would only last a couple of years but you must remember that these things have been discountinued for nearly two decades and that even though the partswere new it dosen't mean that they are in the best of condition due to age. It is wise to get a couple of spares of the crank sensors (will have to be used since they are depleted from the Honda warehouses now) and keep one in a saddlebag for emergencies. This sensor is exposed to alot of high temps due to its location and if you do alot of in town or city driving where temps will build up quick these sensors will go bad sooner, same with the pulse generators located behind the head, heat is their worst enemy. Average life for these parts when the bikes were new were around 50 - 60,000 miles at best.
When my bike began stumbling and backfiring I had to replace both to totally solve the problem. Apparently when either of these go bad theyproduce almost the same symptoms.
Good luck
TNroadrider
TNroadrider is offline
post #3 of 4 (permalink) Old 02-25-2008, 06:15 AM Thread Starter
TNRoadrider:
As my mother used to say, "If it'd been a snake, it would've bit me." I was looking on the rear case. It was right where you said, on the rear of the head.
I replaced the crankshaft position sensor w/ OEM part but, as you say, it may have been sitting on a shelf for a long time. I'll put the pulse generator in, then see where I am.
Thanks for your help!
post #4 of 4 (permalink) Old 02-25-2008, 09:30 AM
Glad to be of help, I hope you get the problem worked out before long, any problems just post again or drop me a PM
TNroadrider
GL1200 Pulse generators question FIBO Goldwing Technical Forum 7 04-28-2013 07:41 AM
GL1200 pulse generators going out or stator problem yoalen Goldwing Technical Forum 27 04-23-2012 11:09 AM
GL1200 Pulse Generators TommyStud Goldwing Technical Forum 15 04-03-2012 12:59 PM
Pulse Generators for GL1200 glothringer Goldwing Technical Forum 6 02-27-2010 11:37 PM
gl1200 pulse generators BASSER Goldwing Technical Forum 3 10-19-2008 10:30 PM
