lowering gl 1200 - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 02-25-2008, 09:58 AM Thread Starter
luckey9
luckey9's Avatar
Year: 1998
Make: GL-1500
Model: GL-1500
Send a message via Yahoo to luckey9
anyone have any new pics. or info on lowering the rear shocks on gf 1200. I have researched most of the older threads on this topic but haven't seen good drawings of the lowering method used by several owners. I would like to see or talk to someone who has seen or done this mod and hear any problems associated with it. Left side looks simple with a u-bracket welded back of the stock mount, however the right side seems more difficult.
Thanks in advance.
luckey9
98 GL-1500 A Candy Apple Red
Previous bikes:
84 GL-1200I
74 gl 1000 Vetter set-up NL-Mexico & return.(sold)
57 Harley Police Special(basket case!)
68 Harley Electra Glide (much the same)
75 250 Honda dirt bike(wrecked)
83 Honda v-65(Crashed) 93 Viargo 11
luckey9 is offline
post #2 of 9 (permalink) Old 02-25-2008, 10:36 AM
William_86's Avatar
Model: GL1500 Aspencade
i would use taller shoes. and you can also lower the seat.. i wouldn't mess with the shocks or suspension. cuz the point is not to lower the bike, but to lower the riding position right?. with a lower bike you will hit everything on the road. kinda dangerous for turning or taking curves
thats just my humble opinion i dont know if you have tried that. ride safe.
William_86 is offline
post #3 of 9 (permalink) Old 02-25-2008, 10:44 AM
Old Hawkeye's Avatar
Luckey9, I think you would be better off either getting your seat redone and having it lowered at that time or getting a Corben seat which is really low. I have a short inseam of 28" and find it hard to keep both feet on the ground. I bought another seat and it ended up being higher. So that's my .5cents worth. Old Hawkeye.
Old Hawkeye.
85 Aspy since New
GWRRA Chpt."Y"ON
Old Hawkeye is offline
post #4 of 9 (permalink) Old 02-25-2008, 10:56 AM
Token Canuk
96aspencade's Avatar
Model: 1996 SE
I've had good luck with both my G/W's re-cutting the seat myself. Removed the cover, mark with a marker & cut with a utility knife. Replace cover with 9/16 staples & staple gun. You can always replace the foam if you take too much & replace with newer material.
Retired Paramedic - 35 yrs
DD # 1138
30,000 miles - Formosa,
'96 GL 1500 SE - 260,k km
'83 Shadow 500
'70 Kawasaki KE-125
'?? Suzuki 80
96aspencade is offline
post #5 of 9 (permalink) Old 02-25-2008, 02:59 PM
lostinflorida's Avatar
I am also cursed with short legs. On my best days I'm only 5'-0". On my worst days, well I'm still 5'-0".
I cut my seat down myself, took at least an inch or inch & a half out. It helped, so does riding 2 up with the wife alot.
I can only get one foot down at a time when stopped.
Best thing is keep the air pressure in the shocks, front and rear.
I would advise from moving the shock attachment location. One day you might need to install a 1500 rear tire/drive. The rubber grommets in the 1200 are not replaceable whenwore out. The 1500 is. Mine has one on it now, and it is a little larger than the 1200 and will rub on hard bumps.
I even had to modify the rear fender and the brake caliper mounting bracket.
"The Duke of" Earl.
PGR member
IBA member #32000
lostinflorida is offline
post #6 of 9 (permalink) Old 02-25-2008, 05:58 PM
badorderbob's Avatar
Year: 1981
Make: Honda Goldwing
Model: Gl 1100
Hi Lucky, I believe this was discussed in an earlier post! Try this, https://www.goldwingfacts.com/forums/forum1/16670.html. Hope this helpsBob
badorderbob is offline
post #7 of 9 (permalink) Old 02-25-2008, 07:47 PM Thread Starter
luckey9
luckey9's Avatar
Year: 1998
Make: GL-1500
Model: GL-1500
I wish to thank all who replied to my lowering question, I now feel the seat option to be the safest especially knowing about the 1500 rear end swap if ever required.
While i'm shoveling snow i shall get right on it !!!
luckey9
Previous bikes:
84 GL-1200I
luckey9 is offline
post #8 of 9 (permalink) Old 02-26-2008, 08:06 AM
Luckey9 I should have added that not only do they recommend cutting the height down, they say the biggest thing is narrow the front up a little bit. This allows your legs to close up the angle a little and that adds some reach!
"The Duke of" Earl.
PGR member
IBA member #32000
post #9 of 9 (permalink) Old 02-26-2008, 09:46 AM
beachbuddy0253's Avatar
send me a pm and i'll send some pictures of brackets i used
beachbuddy0253 is offline
lowering Flybynight Goldwing Technical Forum 20 02-08-2012 09:52 PM
Lowering a 1200 wof49 Goldwing Technical Forum 5 06-27-2011 06:21 AM
Lowering an 84 GL 1200 ramtough_63 Goldwing Technical Forum 15 01-11-2010 07:52 PM
lowering a 1200 aspencade shadowman Goldwing Technical Forum 5 08-10-2009 11:29 PM
lowering Dusty Goldwing Technical Forum 4 07-20-2009 08:48 PM
