broken spark plug wire? broken spark plug boot? - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 03-28-2008, 08:53 PM Thread Starter
AmpGoes211's Avatar
i had the spark plugs out the other day. i don't remember any tugging, but the #3 wire is out of the boot and i'm puzzled at what i see. it looks like the wire just ends, and i don't see how an electrical connection is made between the wire and the spark plug boot. is this normal? i see it has corrosion...not talking about that. surely something must have broken off, right? how do i fix it?
there's a picture of it here
https://www.goldwingfacts.com/photopo.../10763/cat/500
thanks for anydirection you can give.
82 GL1100 Interstate
06 Suzuki Boulevard C50
AmpGoes211 is offline
post #2 of 9 (permalink) Old 03-28-2008, 08:58 PM
teacher's Avatar
Year: 1983
Hey AmpGoes211, If you look inside the boot from hence the wire came, you should see a brass pointed protrusion. That pointed part sticks inside the wire. So just pust the wire back inside the boot. Wait a minute I think that is how it fits inside the coil. On the boot I think you have to cut the insulation back about 1/2", bend the wire over and down the side of the insulation then put it back inside the boot. It's been a while but I'll go down and look at mine.
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
post #3 of 9 (permalink) Old 03-28-2008, 09:08 PM Thread Starter
AmpGoes211's Avatar
i was having a tough time seeing anything inside the boot.my flashlight and my glasses kept bickering with one another
post #4 of 9 (permalink) Old 03-28-2008, 09:09 PM
teacher's Avatar
Year: 1983
I was right the first time................If you look inside the boot from hence the wire came, you should see a brass pointed protrusion. That pointed part sticks inside the wire. So just pust the wire back inside the boot.
~Butch~~~
teacher is offline
post #5 of 9 (permalink) Old 03-28-2008, 09:18 PM Thread Starter
AmpGoes211's Avatar
oh ok...thanks so much for your help. much appreciated
post #6 of 9 (permalink) Old 03-28-2008, 09:18 PM
If it the same as the 1000,it is actualy a screw that protrudes so you screw rather than push the wire onto the cap.
Easy Rider is offline
post #7 of 9 (permalink) Old 03-28-2008, 09:22 PM
teacher's Avatar
Year: 1983
You might be right Easy Rider. I've never look close enough to notice the threads having a twist to them.....................Good call.
~Butch~~~
teacher is offline
post #8 of 9 (permalink) Old 03-28-2008, 10:31 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
Yes, it screws on the end that goes to the plug. But just pushes into the coil. There is a compression nut that holds it in the coil.
Raymond
Silicon Sam is offline
post #9 of 9 (permalink) Old 03-29-2008, 07:36 AM
Guru
Hatchetman's Avatar
see if you have just a little excess wire there. if you do, cut around 1/4 inch off so the boot screw will auger into new wire. pull the little rubber cap up the wire out of your way, grease will help make it slide. now you screw the plug boot into the wire and than slide the little rubber cap back over the top of the boot.
Hatchetman is offline
Spark plug wire john424 For Sale/Wanted Forum 7 04-15-2009 10:29 PM
Spark Plug Wire smketr1100 Goldwing Technical Forum 4 05-14-2007 11:07 PM
81 GL 1100 spark plug wire help richwins54 Goldwing Technical Forum 6 08-24-2006 12:05 PM
Broken Spark Plug Scott_Moore Goldwing Technical Forum 13 04-09-2006 09:24 PM
Broken spark plug. HELP!!!!! MarkEddy Goldwing Technical Forum 24 11-25-2005 07:21 AM
