windshield replacement - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 04-02-2008, 08:14 PM Thread Starter
hello, Im looking to replace my windshield,this how far ive got,, removed 3 screws covered with gold caps on either side of the fairing,i cant see where else to remove any more,very new to this bike and don't want to make a mistake,any help would be appreciated. thank-you Dave
bigoldguy is offline
post #2 of 2 (permalink) Old 04-02-2008, 10:55 PM
Guru
Hatchetman's Avatar
Hi Dave. when I pulled mine off it had 3 "U" shaped grooves on the bottom end so it could slide strait up & out but I also replaced my mirrors at the same time so the old ones were off when I did the windshield. As far as I can remember, i had my hand crammed in through the signal light holes to access the nuts on the inside of the fairing. Tight fit for me because I wear a size 17 wedding band. Look at your new windshield and you will see the grooves at the bottom. Mine was sticky or tight, Cant remember which one but with a lil wiggling it slid strait up and off.
Hatchetman is offline
Windshield replacement wingerjr Goldwing Technical Forum 7 07-21-2011 05:38 AM
Windshield Replacement arrowhead_40 General Motorcycle Discussion Forum 5 02-26-2008 11:40 AM
Replacement windshield zeke 32 Goldwing Technical Forum 4 10-05-2007 10:06 PM
Windshield Replacement RiverBum Goldwing Technical Forum 8 11-07-2006 11:58 PM
Windshield replacement tlc Goldwing Technical Forum 14 09-28-2006 06:15 PM
