84 GL1200 Aspy Starting Issue / Charging Issue - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 04-04-2008, 09:21 PM Thread Starter
PTK502's Avatar
Send a message via AIM to PTK502
Ok First off. I want to Thank Everyone who has responded to my other posts and that have helped me getting thru some pain in the butt issues....
Now on to the new one, after spending a good 6 hrs on Fixing the Stator Wire issue, then the Starter Soleniod Fuse fix ... I found that my Starter Button is not working and im still not charging, though i think that might be a toast battery.
So I got the jumpers on the bike, get it running let it warm up. Then i shut it down to open the tank area and went to restart it and found that the button wouldnt even give me a click... If i take a screw driver and tap the poles on the soleniod it would crank when hooked to a jump battery...
I have checked and rechecked all the fuses, the dogbone has been changed to a blade 30amp fuse and the 2 red wires tied in to it.
I get all the lights and even the green neutral light.
Also I am only charging at 13-14volts... is that normal???
Thanks for any input or suggestions?
Also i have searched the board pretty well but i may have missed something ...
Thanks!!!
If It Ain\'t Broke, Dont Fix It...
Just Make It Faster!!!
PTK502 is offline
post #2 of 19 (permalink) Old 04-05-2008, 07:56 AM
retiredintime's Avatar
14 volts is a good charge voltage for a 12 volt battery. Sounds like you may have two issues. A bad battery and possibly your starter button is bad/dirty. Do the headlights go out when you push the start button? They should.
I would start by getting a new battery and then troubleshoot the starter button problem then. It is very hard to fix a problem when you have several at the same time. Fix one at a time...
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #3 of 19 (permalink) Old 04-05-2008, 08:14 AM Thread Starter
PTK502's Avatar
thanks for the Reply, The battery is new, im hoping that it didnt get toasted with all the stuff going on with the bike.
Im going to check the Starter Button today, going to take it apart and clean it then im going to recheck the Connections at the relay and if needed rebuild those...
also going to see if Auto Zone can check the battery for me, if its bad looks like im taking an hr drive down to Millstone to swap it out...
PTK502 is offline
post #4 of 19 (permalink) Old 04-05-2008, 09:17 AM
Keystone742's Avatar
Year: 1984
Model: Gl1200I
Try not to get discouraged,we've all been there. You're making progress, one step at a time. Soon you'll have that baby up and running, and the entire summer ahead of you to ride thru.Like Retiredintime said troubleshoot the starter button, and have the battery checked. Keep us informed.
1984 1200I Candy Cobalt Blue over Bright Silver Metallic w/ Black & Silver Marbling. Poorboy alternator. Progressive springs and a comfy gel seat.
Keystone742 is offline
post #5 of 19 (permalink) Old 04-05-2008, 09:33 AM
motor22's Avatar
Dont forget to check the kill switch. Its happened to the best of us.
Training will keep you alive. Practice evasive and braking techniques. Please stay safe.
Scott
My Baby
08 1800 Airbag
86 1200SE-i (gone)
78 Suzuki GS550 (gone)
85 Yamaha 750 Seca (gone)
00 Suzuki 800 Intruder (gone)
motor22 is offline
post #6 of 19 (permalink) Old 04-05-2008, 10:15 AM
EDDIE W's Avatar
did the starter button work ok before you started working on it, and did you cut the wires of the plug at the top of the solenoid, if you did that you just may have wired it back wrong
GSVH
\'88 GL1500
EDDIE W is offline
post #7 of 19 (permalink) Old 04-05-2008, 10:29 AM Thread Starter
PTK502's Avatar
Well...
Lets just say, its always good to double and triple check ur connections...
I had left the cables a little long when i was working on the relay... so when i stuffed them into the crevice i must have pulled something... goes to show dont stuff things when its running...
I re-checked all of my relay connections and it appears the connectors i used failed when they got pulled on. So I re-did the Yellow/red and Green/Red and used a new crimp tool...
Bam it click... battery is a little low, just got off the phone with Autozone and they are going to check it for me and give it a charge... it's a maintence free that is less then a month old so heres hoping...
Thanks to Everyone who replied, its greatly GREATLY appreciated...
Ill post again after the battery has been checked....
PTK502 is offline
post #8 of 19 (permalink) Old 04-05-2008, 02:36 PM
EDDIE W's Avatar
dont you just love it when a plan comes together, have a big cigar and a tall beer
GSVH
\'88 GL1500
EDDIE W is offline
post #9 of 19 (permalink) Old 04-05-2008, 08:26 PM Thread Starter
PTK502's Avatar
Well, after close to 8 solid hrs of wrenching, and 4 trips to autozone... I think for today Im done...
Things accomplished today:
1: Fixed Starter Issue
2: Double Checked all connections, re-crimped everything and re-taped
3: Changed Spark plugs
4: Changed Fuel Filter
5: Changed out aux driving lights
6: fixed and re-wired fan ( its still on a switch but now has a relay and safer location)
7: Cleaned Air Filter
Now I have to start new post after researching some other issue i found while taking her for a 5 mile tour.....
Thanks again for everyones input and replys....
Tony
PTK502 is offline
post #10 of 19 (permalink) Old 04-06-2008, 06:28 AM
Year: 1984
Model: Gl1200I
Sounds like you had a good day. A very good day.
GL1200 carb issue, or electrical issue ole wing Goldwing Technical Forum 22 09-25-2012 05:16 AM
GL1200 charging issue freewing Goldwing Technical Forum 17 07-17-2012 04:36 PM
GL1200 LTD charging issue jmd10259 Goldwing Technical Forum 19 05-21-2012 08:31 PM
GL1200 Aspencade Charging Issue TommyStud Goldwing Technical Forum 31 07-04-2011 06:01 PM
starting/charging?/running issue gl1000 2Dahorizon Goldwing Technical Forum 17 08-26-2009 09:49 AM
