78 GL1000 oil leak - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 05-07-2008, 02:56 PM Thread Starter
wanger55's Avatar
I am experiencing an oil leak on my GL1000. It is only a small leak, maybe 4 to 6 drops in a couple hours riding, but I thought it was the left valve cover and replaced the gasket. It is not leaking as bad, but is still leaking. Could it be coming from somewhere else under the engine? Are these bikes bad to leak oil? Thanks, Mike
Michael Baker
wanger55 is offline
post #2 of 2 (permalink) Old 05-07-2008, 03:00 PM
two places on the left side that might leak (okay there are more, but the two most common) valve cover gasket... and shifter seal
less common.... valve cover bolt gaskets and cam seals
rcmatt007 is offline
Oil Leak on GL1000 77GL1000Wing Goldwing Technical Forum 5 08-21-2012 11:34 AM
GL1000 oil leak from water pump zeldar Goldwing Technical Forum 4 05-25-2011 08:11 AM
79 GL1000 oil leak... Gary_GL1000 Goldwing Technical Forum 2 06-25-2007 08:52 PM
GL1000 Oil leak s12eaton Goldwing Technical Forum 7 09-05-2006 08:35 AM
1979 GL1000 oil leak question TxMike Goldwing Technical Forum 22 08-25-2005 09:20 AM
