84 GL1200 start problem - Steve Saunders Goldwing Forums
post #1 of 16 (permalink) Old 05-18-2008, 11:58 AM Thread Starter
34Mike's Avatar
Bought a 84 Aspencade yesterday. This morning it would barely crank like a low battery. Hooked jumper cables(good "00"welding cable type)to the car(not running)and it cranked but still sluggish. Can the starter brushes be replaced with starter still on engine or do I have to pull the engine? HELP!!
Ride like you want to ride tomorrow. Mike
34Mike is offline
post #2 of 16 (permalink) Old 05-18-2008, 01:06 PM
ARKnapp's Avatar
Model: None
Welcome, your not screwed, you do have a bit of work to do. At 1984 your bike will ned maineance, the usual but most neglect the electrics.
Check the battery for charged condition, with a hydrometer, any thing else leaves you guessing. Do all the wiring and connectors, clean and be sure connections are good.
If the stater is sluggish you must determine whether its the electrical supply or the motor itself or both.
Ceck the simple things first.
ARKnapp is offline
post #3 of 16 (permalink) Old 05-18-2008, 02:12 PM
retiredintime's Avatar
If it turns out that you do need to remove the starter you do not need to remove the engine. On most you need to remove the shift lever, One bolt. On some you need to remove the left side exhaust headers to get enough room. Fairly easy really.
If you take the starter apart be carefull with the shim washers on the shaft. Make a diagram and show how many there are so you get them back on right. Look at the armature for signs of dragging which will mean a bad bushing.
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #4 of 16 (permalink) Old 05-18-2008, 03:04 PM Thread Starter
34Mike's Avatar
Thanks. I think it's probably the starter because even hooked to a car battery it is sluggish. Ijumped acrossthe solenoid and got the same results. I haven't downloaded the factory manual yet but the Clymer manual I got with the bike states on the 84 & 85 models "Do not remove the starter with the engine in the frame. The starter drive sproket and drive chain is not captured within a guide like on the 86& 87 modelsand will move away from the hole in the engine rear cover and the starter cannot be reinstalled onto these 2 items" . I'm crossing my fingers that I don't have to take it somewhere and pay big $$ to pull the engine. I feel confident I could pull the starter and rebuild it myself if I don't have to pull the engine.
34Mike is offline
post #5 of 16 (permalink) Old 05-18-2008, 05:01 PM
Again...You do not need to remove the engine. Leave on sidestand while you do the job....
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
post #6 of 16 (permalink) Old 05-18-2008, 06:09 PM Thread Starter
34Mike's Avatar
Thanks Bob. I have read that you don't even have to leave it on the side stand but I WILL just to be sureOH....and Hi from a fellow Ham, KD5VHF here. 73
34Mike is offline
post #7 of 16 (permalink) Old 05-18-2008, 09:31 PM
muaymendez1's Avatar
Ok you HAMS theHOGS are on another site.
DOnt remove the engine. As said before 2 bolts + the wire stud wiglle out. Reinstalling has become a bit troublesome for a few but its not impossible. After you do it a few times itl slide in like butter.
I have returned to the wonderful saunders forum after a 2 year hiatus. I realilzed the grass can never be greener.
muaymendez1 is offline
post #8 of 16 (permalink) Old 05-24-2008, 10:14 PM Thread Starter
34Mike's Avatar
I pulled the starter this morning to see how bad it was and order whatever parts were needed. Other than being full of the black dust,one of the brushes was stuck in the guide. Gave the whole thing a good cleaning, made sure the brushes would slide in the guidesand new grease in the front and it now works GREAT! It now starts better hot than it did cold before. Thanks to everyone for the help.
34Mike is offline
post #9 of 16 (permalink) Old 09-16-2008, 07:13 AM
crusty's Avatar
Send a message via AIM to crusty
hey! i got a similar problem, mine was cranking just fine and then started to just click, batt. is new, think it might just be a ground problem, what do you think?
Crusty
Mike O.
crusty is offline
post #10 of 16 (permalink) Old 09-16-2008, 08:15 AM
MDKramer's Avatar
Model: GL1100 / GL1200
Crusty, I'd start by checking all connections for tightness as well as corrosion. Start at the battery and work your way to the starter motor, then go back to the battery and work your way to ground.
Make sure you actually take the connections apart, don't just glance at 'em and say "looks clean", you can't see what's between the mating surfaces.
And do NOT discount the battery just because it's new. N-E-W doesn't spell GOOD in any dictionary I've ever picked up. Get a hydrometer and give it a check as well.
Mike Kramer
"Learn from the past, set vivid, detailed goals for the future, and live in the only moment of time over which you have any control: Now."
Denis Waitley
MDKramer is offline
94 1500 start problem Michigan Gator Goldwing Technical Forum 6 06-12-2010 12:35 PM
Start switch problem Tex Goldwing Technical Forum 9 06-03-2009 06:26 PM
'83 Interstate start problem bellcons Goldwing Technical Forum 6 08-26-2008 11:41 PM
Start up problem zonk3939 Goldwing Technical Forum 6 11-27-2005 12:13 PM
cold start problem deputy steve Goldwing Technical Forum 5 11-10-2005 01:43 PM
