'89 GL1500 charging issue - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 06-13-2008, 02:32 PM Thread Starter
wingannaprayer's Avatar
This has driven me crazy. With a fully charged battery and running the engine for about 30 minutes, it dies. Tested voltage going to battery and only register 12v as oppose to the 13.5-15.0v the manual calls for. Broke open the alternator and brushes were marginal. Cleaned alternator and replaced brushes. Still same result. Checked wire harness for continuity. All okay. This may seem like a stupid question, but I notice that when I hit a bad bump (i.e., railroad track) the bike shuts off. Turn key off and back on it starts which sounds like bank angle indicator. Could these two issues be related? Certainly would appreciate any help you fine folks can offer. Thanks in advance. P.S. '89 Gl1500
wingannaprayer is offline
post #2 of 6 (permalink) Old 06-13-2008, 02:59 PM
Monkey with a Football
Rudy's Avatar
The shutoff problem probably is the BAS as you suspect. I don't think the two problems are related. You should call your VIN into any Honda repair department and let them verify if the warranty factory recall on the BAS was done. If not, get that taken care of.
Check all connections between the alt and the batt visually, not just electrically.
Also make sure the dog bone main fuse is not cracked by removing it from the holder and see if it falls apart.
Rudy
wasn't too much fun”
Rudy is offline
post #3 of 6 (permalink) Old 06-13-2008, 03:13 PM
SHREK snr's Avatar
Seems to ms that your alternator is going west, if you are not putting enough charge back into your battery. How old is your battery? double check the wires to the brushes and the connections. Good luck if not get a Compufire .
1982 cany red 1100 Interstate
Chrome wont get you home. / Skype goldwingnut /RBLR . "When You Go Home, Tell Them Of Us And Say, For Your Tomorrow we gave our today" Colin
SHREK snr is offline
post #4 of 6 (permalink) Old 06-13-2008, 10:44 PM
Guru
Hatchetman's Avatar
Even a crappy ignition switch will shut down the charging system. If you wiggle the key, does your voltage fluctuate?
Hatchetman is offline
post #5 of 6 (permalink) Old 07-01-2008, 09:26 PM
westgl's Avatar
Hey all,
Does the 88' 89' GL1500/6 displayvoltage on the LCD??
Thanks
Westwing
Current Bikes,
2005 Burgman 650 20K
westgl is offline
post #6 of 6 (permalink) Old 07-02-2008, 12:15 AM
THE DUDE's Avatar
HEY
Sounds like something is loose, run it and move sit around like H man says , and other stuff, like simulate the track bump, get it
YOU KNOW
THE DUDE
Remember allways be cool
stress is bad
Ride on dudes
THE DUDE is offline
GL1200 LTD charging issue jmd10259 Goldwing Technical Forum 19 05-21-2012 09:31 PM
85 1200i charging issue???? khazl Goldwing Technical Forum 7 09-22-2011 11:09 AM
GL1100 Charging issue...again Broke Winger Goldwing Technical Forum 6 04-25-2011 05:02 PM
Charging Issue Bondy Goldwing Technical Forum 7 03-22-2009 01:03 PM
84 GL1200 Aspy Starting Issue / Charging Issue PTK502 Goldwing Technical Forum 18 04-18-2008 07:40 PM
