'88 Asencade not charging. Please confirm my diagnosis. - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 06-24-2008, 05:27 AM Thread Starter
ramjam's Avatar
Hello all,
My brother's Wing just shut off at a stop sign the other day. No lights, horn, nothing.
Get her back home and charged the battery and start taking off panels. There's no bad fuses or loose connections.
Setting cold and off the battery reads 12.4 volts. Started and running @ 2000 rpm the voltage across the terminals reads 11.1 volts.
Now, I'm no mechanic , heck before I started reading this page I couldn't even spell mechanic, but I say his alternator is shot.
Where should we seek a replacement
All opinions welcome.
Thanks, Rick
ramjam is offline
post #2 of 4 (permalink) Old 06-24-2008, 06:43 AM
Foosman(5)'s Avatar
Model: 88 GL 1500
Your diagnosis soundsreasonable.
Try starting the bike and disconnect the battery. The engine should die if the alternator is not putting out system voltage for the ignition system. If it runs, measure the voltage at the battery cable leads.
Texas _Foosman
1988 GL1500
Foosman(5) is offline
post #3 of 4 (permalink) Old 06-24-2008, 06:45 AM
Foosman(5)'s Avatar
Model: 88 GL 1500
Does that 88 have a center LED display on the dash?
Texas _Foosman
1988 GL1500
post #4 of 4 (permalink) Old 06-24-2008, 07:56 AM
Matt G's Avatar
Send a message via AIM to Matt G Send a message via Yahoo to Matt G
you should show 13-14 volts at idle. The alternator on the 1500s charges at idle, no need to go any higher on RPM. Pull the alternator and break it down, it might be something as simple as stuck brushes.
All 1500s have a center LED display.
Oh, there were no Aspencades in 1988, all GL1500s were just that, a GL1500, all came with reverse, stereo, cruise, intercom.
Current Goldwing:
1988 GL1500 Wings of Freedom
We tried voting with the Ballot box, When do we start voting from the Ammo box, and am I allowed only one vote ?
Matt G is offline
1983 Asencade Radio njjoe1 For Sale/Wanted Forum 0 04-02-2008 08:00 PM
just to confirm silverfox's thread Tattoo Taffy Miscellaneous Forum 2 04-01-2008 09:26 AM
Taffy's first diagnosis Rudy Fun Forum 21 09-08-2007 12:20 AM
Aaadd Diagnosis pinkpork Fun Forum 2 02-02-2007 04:46 PM
Weight recommendations on the 96 Asencade Inland Goldwing Technical Forum 2 07-13-2004 02:03 AM
