Bearing spun in hub of 88 GL1500 rear tire, now what? - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 06-25-2008, 10:12 AM Thread Starter
It just keeps getting better with this bike. I noticed a slight sideways movement in the rear tire while the bike was on its centerstand. I took the tire off to maybe replace the bearings and the bearing outer race on the disc side spins in the rim. How can this be repaired? Loctite? Weld up and re machine for new bearing to press fit? Machine out and sleeve? Not much material for that. Any suggestions? New rim big bucks, I'm on a budget.
Thanks!
1985 Shadow (15000 mi,deer fatality)
1981 GL1100 (40000 mi)
1985 GL1200A (20000 mi)
1988 GL1500 (fixn all the time)
bugzapper1 is offline
post #2 of 3 (permalink) Old 06-25-2008, 10:26 AM
Matt G's Avatar
Send a message via AIM to Matt G Send a message via Yahoo to Matt G
easiest way is to get a complete drive assembly off of a trike conversion and change out the rear end to a newer bike. The rear wheel and drive were only used on the 88-89 models. by changing to a newer model, parts are easier to find. You would need the final drive, wheel assembly,spline assembly, caliper and caliper mount.
Or I have the wheel and drive unit from my 88 if you want to make a offer.
Current Goldwing:
1988 GL1500 Wings of Freedom
We tried voting with the Ballot box, When do we start voting from the Ammo box, and am I allowed only one vote ?
Matt G is offline
post #3 of 3 (permalink) Old 06-25-2008, 08:09 PM
Foosman(5)'s Avatar
Model: 88 GL 1500
I would not have that hub repaired. Find one on e-bay.
Texas _Foosman
1988 GL1500
Foosman(5) is offline
Rear Bearing Removal GL1500 us385south Goldwing Technical Forum 11 08-11-2013 09:09 AM
'98 GL1500 Rear wheel bearing replacements Paddy Goldwing Technical Forum 5 10-19-2011 10:13 AM
Bad Rear Wheel Bearing GL1500 gwing82 Goldwing Technical Forum 7 04-20-2011 05:58 PM
Gearheads: Ever spun a rod bearing or broke a crankshaft? da_bull Fun Forum 8 12-12-2010 11:26 AM
Bearing retainers, front and rear tire keithg64 Goldwing Technical Forum 4 05-19-2009 09:49 PM
