J & M Microphone Bracket Broken on Open Face Helmet - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 07-16-2008, 11:58 AM Thread Starter
The bracket that holds the microphone to my open face helmet is broken.
This is a J & M aftermarket setup, not a Hondaline setup.
The break is just above where the bracket screws to the helmet.
Any ideas would be appreciated.
OldWingRider is offline
post #2 of 7 (permalink) Old 07-16-2008, 12:04 PM
FIRE UP's Avatar
Year: 2008
Old Wing rider,
I also have the J&M set-up on open face helmets. I would like to see the break, in case my set-up does the same thing. Is it possible to send a pic of the break and then I might be able to suggest a fix or two, depending on what all the materials are made of.
Scott
Scott & Karla
RETIRED!
FIRE UP is offline
post #3 of 7 (permalink) Old 07-16-2008, 01:32 PM Thread Starter
Here is pic. I hope you can see it.
http://www.flickr.com/photos/[email protected]/2674014653/
post #4 of 7 (permalink) Old 07-16-2008, 03:28 PM
Snorebaby's Avatar
That is an older J&M....the same kind that came with my bike when I bought it. I bought a J&M for my wife and the newer ones are a one piece that connects to the helmet. I like them better.
I don't know what you can do since it is at the stress point of the connection. But you can find them at for less than $70.
http://www.wingstuff.com/pgroup_deta..._w_1Piece_Cord
'15 GL1800 Scarlett
'90 GL 1500 SE Pearl
'86 CMX450 Rebel
'85 GL1200 LTD---SOLD
Patriot Guard Riders #137660
Snorebaby is offline
post #5 of 7 (permalink) Old 07-16-2008, 04:53 PM
I would simply get a tube of the gel style super glue and glue it back on.......I have several helmets that are about half superglue by now......especially my new symax......something falls off of it just about every week......I just superglue it back on. Kit
Kit
Kit Carson is offline
post #6 of 7 (permalink) Old 07-16-2008, 05:14 PM
jimsjinx's Avatar
Model: 1999 1500SE Motortrike
I have found "Goop" from the "ShoeGoo" people, to be very good, and stays somewhat flexible. I clean parts with acetone, and scuff em a little and clamp em together.
"We are put here, to take care of each other"
jimsjinx is offline
post #7 of 7 (permalink) Old 07-16-2008, 05:15 PM
FIRE UP's Avatar
Year: 2008
Old Wing rider,
If what I'm seeing is correct, the mic (boom) mounting point is broke. What's the two circles, screws of some type, allen screws? etc? My thoughts on something like this, it's broken anyway so what harm would it be to try and fix it. Worst comes to worst, you'll have to buy a new one. So that said, like I said, I can't tell what the materials are made of so, if it's some sort of plastic, then Home Depot and many auto parts stores sell all kinds of epoxies. I've tried one and my son used one on his broken overflow tank on his Toyota and both applications worked flawless. The glue joint was stronger then factory stuff. It doesn't take much to do the work. A tiny bit of prep, mix the epoxy, apply, wait, it's done. If it doesn't work, what are you out, about $5.00 for the glue, that's it. Then go get a new one. If it does, you get it fixed and, you can use the remainder of the epoxy for other fixes. Good luck.
Scott
Scott & Karla
RETIRED!
FIRE UP is offline
open face helmet walkabout General Motorcycle Discussion Forum 0 05-03-2012 05:51 PM
Arai SZ-M Open Face Helmet Hawker22 General Motorcycle Discussion Forum 4 07-16-2010 07:59 PM
Adding speakers and microphone to full-face helmet pstelter Goldwing Technical Forum 1 07-17-2009 01:55 PM
OPEN FACE HELMET duffytclown For Sale/Wanted Forum 8 06-09-2008 04:23 PM
face protection with an open-face helmet t3hirdeye General Motorcycle Discussion Forum 15 07-18-2007 09:46 AM
