Plastic Repair - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 07-21-2008, 05:18 PM Thread Starter
Jsalpha2's Avatar
Thanks to the people at this forum.
I did a search on plastic repair, went and got some black ABS cement, and ABS Cleaner, Oatey part#30779, and things worked perfectly. My local Lowes did not have the Oatey part#30999 ABS cement, but did have the cleaner. So I went to Ace Hardware and they had no Oatey products, but did have what they said to be the same thing in the store brand. Ace ABS cement medium body black #44055.
I took the top half of the trunk off, cleaned the cracks in the bottom half, glued them and replaced the top. I am very happy.
For anyone else new to the forum, read, read, search and read some more.
Most of the questions have already been answered, and if you need more help
the people here are great.
Wineberry-The most refreshing color.
Jsalpha2 is offline
post #2 of 10 (permalink) Old 07-21-2008, 06:13 PM
Motosickle's Avatar
Location: Orlando(in the shadow of the mouse), Florida, USA
Send a message via Yahoo to Motosickle
thanks for doing the research and sharing it! i can add that to my list of repair methods.
robin
A proud Patriot Guard Rider........because it\'s the right thing to do!
Motosickle is offline
post #3 of 10 (permalink) Old 07-26-2008, 02:44 PM
Send a message via AIM to gtracer3 Send a message via Yahoo to gtracer3
Hi
I fixed my the cracks in my bags and trunk with a soldering gun. Just clean the dirt off the area and match up the crack. Melt the joint as far thru as you can in a few places. Let it cool. Then do some on the other side. Fill in the rest of crack and your go to go. If you can find some of the same plastic that is not used,(unused brackets come in handy) You can use it as filler.
I've fixed plastic radiators the same way. You just have to be careful to get all the antifreeze of. Carb cleaner works good here. I even fixed my broken plastic pool pump and filter this way. Extra filler material and penitration is the key for a good repair. I hope this helps someone save a little.
Now if anyone know a good way to lower a GL1200 it would help me. I have short legs. LOL
gtracer3 is offline
post #4 of 10 (permalink) Old 07-26-2008, 04:00 PM
Model: 2002 GL1800
You can actually buy an ABS welder. It is like a heatgun with a special tip that you insert abs rods to weld with. This is the best method and will repair as strong as new.
The ABS pipe glue works ok, but it won't always hold unless you can really coat the pieces. It is really only made to bond two pieces together. so if you can apply another piece over the crack and glue it that will work better.
2002 GL1800 Yellow the fastest color.
1989 Pacific Coast pearl white 18K
previous
1986 SEI
1983 Aspencade wineberry
1972 Yamaha DS7
kccode1 is offline
post #5 of 10 (permalink) Old 08-05-2008, 01:39 PM
Send a message via Yahoo to softshoes
I did a pile of plastic repair on my GL1100I using ABS glue and fiberglass cloth. Works great and really strong after it dries completely.
softshoes is offline
post #6 of 10 (permalink) Old 08-05-2008, 07:00 PM
Passed On, R.I.P.
Bagmaster's Avatar
softshoes has it right on that, repairs with the glue can have fiberglass layered into it before it sets up too much.
Michael
USS Saratoga, ships company
Bagmaster, our former forum Toolmaster and friend, is no longer with us. He passed away in February 2012.
The roads and byways, no matter how beautiful and exhilarating, are a lonelier place now. RIP Bagmaster (Baggy).
Bagmaster is offline
post #7 of 10 (permalink) Old 10-09-2011, 05:35 PM
saltmar14's Avatar
Model: 2004 gl1800
Are these still the best ideas on repairing a crack on a trunk lid? I found a little crack on the back corner (form rear of bike),of the lid and want to stop it from running. don't think there is enough room to add plastic as it is lip that seals.
current bikes
04 gl1800
85 limited edition
82 cm250c
previous bikes
early 80\'s 500 w/ add on fairing
xl 250 enduro (wish they made them like this still)
saltmar14 is offline
post #8 of 10 (permalink) Old 10-10-2011, 06:59 PM
BUDDTWO's Avatar
I have used this method Buy some abs plastic (I got a couple of unions the file them down to get shavings) Take your abs glue and mix in the shavings make a good paste out of it and apply it to your crack it will bond the abs and give it more reinforcement.I fixed a crack in the bottom of my saddle bag and it works good . Hal
GWRRA 1984 1200 aspy 1985 1200 aspy 1996 1500 aspy
BUDDTWO is offline
post #9 of 10 (permalink) Old 10-10-2011, 06:59 PM
BUDDTWO's Avatar
BUDDTWO is offline
post #10 of 10 (permalink) Old 10-11-2011, 12:08 AM
saltmar14's Avatar
Model: 2004 gl1800
thanks will give it a try. in another post i was looking for a left side cover for my 85 limited as mine fell off and was run over, i found a replacement stud and they came with JB weld which i'll try to fix the panel.
current bikes
04 gl1800
85 limited edition
82 cm250c
previous bikes
Trunk/ ABS plastic repair GreyDino Goldwing Technical Forum 17 06-27-2011 08:57 AM
Vetter Bag Plastic Repair Dirt Road Cowboy Goldwing Technical Forum 6 01-27-2011 01:36 PM
ABS plastic repair wingd Goldwing Technical Forum 8 09-14-2010 08:00 AM
1984 GL1200A Plastic Repair b679995 Goldwing Technical Forum 8 04-18-2008 06:36 AM
plastic repair woodbutcher Goldwing Technical Forum 4 02-14-2008 12:30 AM
