Fork seals, dustcaps, fork oil ,or ATF GL1200 A - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 07-24-2008, 05:12 AM Thread Starter
muaymendez1's Avatar
First I appologize for bringing this subject up again.I found alot on the search but have some specific questions.
I plan to do this in my driveway. I have no garage so I am avoiding pullng the forks off the bike.As far as seals , I know I need the fok seals but should I get anything else, Dust caps,O rings,Fork oil. Should I tae apart he antidive mech and replace the o rings in there as well.
I read n the manual that there is a bolt n the fork that has to be turned,I am having trouble understanding,The picture looks lie an allen wrench up through the center of the fork from the bottom????
I have done heads and rebuilt carbs but the forks are intimidating me.
are the MT 90\ 16 Avon Venoms the right size for this bike
Hope this doesnt start a S storm of comments about tires
I have returned to the wonderful saunders forum after a 2 year hiatus. I realilzed the grass can never be greener.
muaymendez1 is offline
post #2 of 5 (permalink) Old 07-24-2008, 07:00 AM
simonone's Avatar
There is a allen screw at the bottom of the fork after removing axle cap you will see it. It must be started before you release the spring tension or you will not be able to later. I use a impact air gun to start it, then you can remove it later when you have taken the fork apart.
I'm not very good at explaining things, hope this helps.
If it ain\'t broke it will be !
1988 GL1500
simonone is offline
post #3 of 5 (permalink) Old 07-24-2008, 07:31 AM
RB
RB's Avatar
Send a message via AIM to RB
The allen bolt can only be seen if you lay on your back and look up into the bottom of the forks..you should probably replace the bushings..if any of the copper is worn off. If you leave the forks on the bike to do this..make sure you block it up carefully you have to "bounce" the tube bottoms off(after removing the retaining clip) and you don't want the bike moving while you are doing that. Helps to have someone hold the bike, sit on it and steady it.
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #4 of 5 (permalink) Old 08-25-2008, 06:13 AM Thread Starter
the allen bolt is a 6mm.
Thanks for the info guys.
post #5 of 5 (permalink) Old 08-25-2008, 06:49 AM
Nightrider1's Avatar
Send a message via MSN to Nightrider1 Send a message via Yahoo to Nightrider1
Hello.
When I replaced the fork oil in my 1100, I left them on my bike. I jacked it up with a piece of plywood on the jack to avoid messing up any of the aluminum casing. Then I put a block under it, Pumped the shocks up and down to get all the old fluid out, and put the seals on, then filled it withthe recommended amount off ATM fluid. Simpple, after the first one.
The seal kit comes with the seal,, the dust cap, and the bottom O-Ring. Make sure you do not damage your 2 Metal O-Rings or circlip. Also, when you put in your ATM fluid, be careful when removing the Fork Caps, because the springs inside will send the cap flying. It has a lot of momentum even after the air is drained, so be careful. I nearly had a black eye becauseof this, LOL
Good Luck,
NightRider1
You meet the best people who ride a Goldwing
Nightrider1 is offline
GL1800 Fork Seals, Fork Oil or Bearings? Rob94 Goldwing Technical Forum 5 02-18-2014 07:49 PM
GL1200 Fork oil leak after changing fluid and seals. dzbell Goldwing Technical Forum 10 05-06-2011 12:01 PM
GL1200 fork seals CaliWing Goldwing Technical Forum 6 01-04-2011 05:01 PM
Fork Oil - Is any type of ATF OK? mdbauer1962 Goldwing Technical Forum 10 05-07-2009 02:55 PM
Pyramid Fork Oil Seals? JLGoldwing Goldwing Technical Forum 4 10-16-2007 04:22 PM
