1990 GL1500 Front wheel bearings. - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 08-02-2008, 04:14 PM Thread Starter
Send a message via AIM to shakyone Send a message via MSN to shakyone
I am replacing the front wheel bearings because the bearings felt stiff to me. After removing the bearings, I realized that the bearings were stiff from the amount of preload on them and not because the grease was dried out. Could it be that they need to run this amount of preload because they are ball bearings or is there an issue with the length of the spacer pipe?
Thanks!
Paul
Paul Grant
1990 GL1500, 2001 BMW R1100R, 1978 BMW R80/7
shakyone is offline
post #2 of 4 (permalink) Old 08-03-2008, 01:50 PM
simonone's Avatar
Don't think the frt wheel brgs are preloaded,just install the axle,speedo gear, spacer on rt. side and torque the single axle end bolt at 60 ft. pds.I beleive.This puts pressure against the inner of the bearing. no preload on the brg itself.
If it ain\'t broke it will be !
1988 GL1500
simonone is offline
post #3 of 4 (permalink) Old 08-03-2008, 01:54 PM
grambo's Avatar
there cheap enough and probably ready....should be smooth and firm....your on the right track...always check em when rr tires...p.s. ...rears are harder to get out and might be ready too!!...what year?....50k mmmm...rears still good prob. unless in a damp area
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #4 of 4 (permalink) Old 08-03-2008, 01:55 PM
Monkey with a Football
Rudy's Avatar
The center pipe and the inner races of the bearings work with the outside spacers and the axle.
The bearings themselves are not side loaded.
It never hurts to change them but it sometimes hurts not to.
Rudy
wasn't too much fun”
Rudy is offline
GL1500 Wheel Bearings Replacement (Front and Rear) txtriathlete Goldwing Technical Forum 4 07-20-2012 04:50 PM
1990 gl1500 steering head bearings wingyingy Goldwing Technical Forum 2 03-25-2012 02:17 AM
GL1500 Front and Rear Wheel Bearings Car Toad Goldwing Technical Forum 3 02-15-2011 11:51 AM
Front wheel bearings oharaLTD Goldwing Technical Forum 15 02-13-2011 05:50 PM
gl1500 front wheel bearings hoss1200 Goldwing Technical Forum 3 06-04-2007 09:55 PM
