82 1100I missing when hot? but coil still fires. - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 08-02-2008, 10:50 PM Thread Starter
MADDOG355's Avatar
I noticed thursday my bike was getting hard to start when it was hot, but didn't really pay it much mind. Today I rode it about 5 miles and stopped at a store when I tried to start it up agian it was hard to start and when it did start I noticed it didn'tsound right. It had a dead miss came strait home (about 2 miles) pulled the plug wires it was the rear cyl on the right side (sitting on the bike) changed plug (it looked fine) still missing. just stuck a plug in the cap and turned the motor over and it was sparking fine. Well let everything cool went out just now started up and ran fine all cyl fireing and all pipes getting hot . I just ran some sea foam through the tank before,Could itbe carbon. Or at worst mabie just valves out of adjustment? I have some work about 40 miles away starting monday and need the bike.
MADDOG355 is offline
post #2 of 12 (permalink) Old 08-03-2008, 01:51 AM
Guru
Hatchetman's Avatar
you might have a resister in your spark plug boot failing. you can buy new ones for around $7 each. they dont have to be from honda, but they do have to be designed for a bike. they screw on to your plug wires and the small screw goes into your solid core of your plug wire.
Hatchetman is offline
post #3 of 12 (permalink) Old 08-03-2008, 09:33 AM
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
I would suggest replacing all four plug boots (part number XD05F they are made by NGK) They run about 4 bucks each.
When you replace them cut about an inch off your wires t make sure you will get good clean wire to screw into.
You could also have a bad coil. There could be a crack or thin area inthe coils housing that when hot it allowing spark to "leak" out.
P.G.R. Member ID: 88374
Broke Winger is offline
post #4 of 12 (permalink) Old 08-03-2008, 10:18 AM
SC
SC's Avatar
SeaFoam can break do-do free and clog jets
Get on the interstate and blow the do-do-out
May not be a bad idea to crack a sediment bowl drain screw and see if any do-do comes out
SC is offline
post #5 of 12 (permalink) Old 08-03-2008, 10:39 AM Thread Starter
MADDOG355's Avatar
Thanks for the info guys
Hatchetman I don't see any set screws on the plug caps.
Brokewinger Any chance I could get them at a auto parts store or will I need to order them from someone online or the dealer? What about wires as well?
It did it agian this morning and I removed the plug cap and it is getting spark.
SC I thought about trying to run it out but was afraid with one cyl down I might cause more damage.
I did notice it seemed to miss fire (fire during the exhaust stroke) when it did it this morning.
post #6 of 12 (permalink) Old 08-03-2008, 11:27 AM
Guru
Hatchetman's Avatar
un screw the plug boot from the wire and look inside where the wire came out of.
post #7 of 12 (permalink) Old 08-03-2008, 12:12 PM Thread Starter
MADDOG355's Avatar
Ok I went out and swapped the caps from front to rear, No change still loosing the same cyl.It is like it reaches a cirtain temp (my temp gauge does not work) and you just turn that cyl off.But even cold that cyl does not seem as strong as the rest.
The bike does have the normal hole in the exaust at the end of the head pipe that I patched with jb weld but I have no idea how long it has been riddenwith a major hole in it before I got it so I am really thinking burnt valve. But I am not understandingwhy it seems worse once the bike gets warm.
post #8 of 12 (permalink) Old 08-03-2008, 12:59 PM
grambo's Avatar
i think hatchet's got it ....and bad wires...oh!!... failing pickup too??hatchetman wrote:
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #9 of 12 (permalink) Old 08-03-2008, 02:14 PM
Passed On, R.I.P.
Bagmaster's Avatar
Check the valve clearances, as an engine warms up parts expand. That cylinder may have less valve clearance than the other when cold and close up to nothing once warmed up and holding a valve open, probably the exhaust valve. If the intake valve was hanging open it would backfire through the carbs when it fires. Do a compression check to be sure.
Michael
USS Saratoga, ships company
Bagmaster, our former forum Toolmaster and friend, is no longer with us. He passed away in February 2012.
The roads and byways, no matter how beautiful and exhilarating, are a lonelier place now. RIP Bagmaster (Baggy).
Bagmaster is offline
post #10 of 12 (permalink) Old 08-03-2008, 02:35 PM
retiredintime's Avatar
There is a good possibility..
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
Oklahoma Fires AZgl1800 Miscellaneous Forum 3 08-09-2012 12:11 AM
GL1100 LTD Ignition coil gets instantly Hot bbyboy299 Goldwing Technical Forum 18 10-27-2010 09:30 PM
gl1100 with a full vetter HOT HOT HOT timbrains Goldwing Technical Forum 7 09-03-2010 10:30 AM
Will 83 1100I engine guard fit on an 82 1100I? Timmus Goldwing Technical Forum 2 04-24-2008 06:13 PM
GL1100 coil and GL1200 coil teacher Goldwing Technical Forum 11 12-23-2006 11:02 AM
