What makes carbs Hic-cup - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 08-04-2008, 09:45 AM Thread Starter
northwing's Avatar
I've sorted the electrical problem I posted the other day, thanks for your input (turned out to be a very bad earth), but have another. 2000rpm and above the bike runs great. Below that it hunts and struggles to keep going. While looking at the carbs I could hear a little pop and the carbs moved back. each carb is doing it but at different times. You have to be extra gentle to rev the bike or it just conks, but OK once you hit 2000rpm. A compression test showed 110 lb each side. I did the compression test with both plugs out and it spat back from the plug holes a couple of times. any thoughts greatly appreciated, Jim
1988 Gl1500
If you see a vehicle with a indicator on, the bulb works, if it flashes the relay works, if they turn......they know it\'s on!!!
northwing is offline
post #2 of 5 (permalink) Old 08-04-2008, 10:21 AM
retiredintime's Avatar
I am a little confused. It sounds like you are talking about an engine with 2 cylinders??
I just read your secondary title. You are talking about 2 cylinders! A Honda 250 Dream. Is the timing set properly? Is the mechanical advance free and not frozen? If that is ok then you have carb troubles...
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #3 of 5 (permalink) Old 08-04-2008, 10:24 AM
Jason m's Avatar
I think he is talking about his 250
1982 Int with Vetter V w/lowers
Jason m is offline
post #4 of 5 (permalink) Old 08-04-2008, 10:29 AM Thread Starter
northwing's Avatar
Yep, it's my Honda cb250n (superdream). I use it as a run around. It's easier to get into the center of town with. Tried the wing a couple of times but you just end up sitting in traffic.
1988 Gl1500
post #5 of 5 (permalink) Old 08-04-2008, 10:35 AM Thread Starter
northwing's Avatar
I've checked the timming andadvance systemwith a strobe and it's working great. Carbs off idle jets out I think!
1988 Gl1500
1978 GL1000 Carbs (early), GL1100 Carbs 77Pinto For Sale/Wanted Forum 5 02-29-2012 07:09 AM
Cup Holder Trainertim77 Goldwing Technical Forum 18 09-18-2009 01:34 AM
A cup of tea SpiderBob Fun Forum 5 09-06-2009 09:33 AM
coffee cup elvisskan General Motorcycle Discussion Forum 17 08-14-2009 09:19 AM
Have a cup on me......UBarW mikef Fun Forum 4 09-17-2008 08:08 PM
