1800 Taillights/Instrument Pane. - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 08-16-2008, 02:03 PM
Guest
Posts: n/a
I have a friend with a2002 GW (non-ABS) and while on the road, all his instruments and taillights stopped working. He replaced the fuse, turned on the switch and immediately blew the new fuse. Any suggestions for troubleshooting or the cause?
post #2 of 3 (permalink) Old 08-16-2008, 05:48 PM
Sounds like a direct short to ground at some point. A wire rubbed and touching the frame. Or ground and power wire shorted together......
Hard to find as meter will show continuity even through the short.....start at the tail light bulb sockets and go from there.
Kit
Kit
Kit Carson is offline
post #3 of 3 (permalink) Old 08-16-2008, 07:15 PM
Guest
Posts: n/a
Kit,
Thanks for the response. Will start with the taillights and let you know when we find the culprit.
Looking to Trade Taillights corey39 For Sale/Wanted Forum 0 07-17-2011 11:55 PM
No headlights, taillights, dashlights, or fuel gauge GL1500 CraigSchnee Goldwing Technical Forum 27 10-24-2010 06:53 AM
Instrument dials for 1500 and 1800 johnsa General Motorcycle Discussion Forum 4 09-16-2010 11:45 PM
LED taillights GSMacLean Goldwing Technical Forum 9 01-25-2007 07:18 AM
Should the taillights be on all the time? brianinmaine Goldwing Technical Forum 4 06-03-2005 09:21 AM
