1800 gear ratio - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 09-21-2008, 09:48 PM Thread Starter
Does anyone make a differentring gear ratio that will lower the RPMs at highway speeds
kenracer is offline
post #2 of 3 (permalink) Old 09-21-2008, 10:59 PM
Senior Guru
Oregonwinger's Avatar
I wouldn't be a bit concerned about the rpm. It's quite happy at that rpm. It's a short stroke engine. If you do that, then everything else is affected, like starting out in first. (clutch burden) It has the power to start out in 4th, but at what cost to the clutch. Not to mention upsetting many other parameters, like the speedo, cruise, emissions, etc. Of course, the speedo would be way off, since the speedo signal is taken off the output shaft. The bike works perfect the way it is, in spite of "ugly headlights" I love the sound of it at 70-80.
BOB
Oregonwinger is offline
post #3 of 3 (permalink) Old 09-22-2008, 10:26 AM
Daveo's Avatar
I always felt (even on the 1500) that there should be a 6th gear. With the amount of grunt the 1800 engine has, imagine the gas mileage improvement.
Owned Previously:
SL100 1974-1976 9,000mi
CB175 1975-1976 100mi
CL350 1975-1980 20,000mi
CB550K 1978-1982 20,000mi
GL1000 1988-1993 2,500 (got the 1500, never looked back
GL1500 1989-1997 50,000mi
Daveo is offline
Gear Ratio difference 81-82 Rumple Goldwing Technical Forum 12 03-19-2012 12:40 AM
Another gear ratio question dan filipi Goldwing Technical Forum 9 10-03-2011 10:39 PM
Gear ratio Nightrider1 Goldwing Technical Forum 12 11-11-2010 11:22 AM
gear ratio skoto1 Goldwing Technical Forum 16 05-14-2009 11:38 PM
Gear ratio question dan filipi Goldwing Technical Forum 6 10-26-2006 12:00 PM
