center stand VS. side stand - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 09-29-2008, 11:50 PM Thread Starter
CBW
CBW's Avatar
I have been riding for a long time on a lot of different bikes, however my new (to me) GL1200 isthe first bike I've had with a center stand.
Here's the big question, I didn't see anyone else posit this one, so here goes;
I commute on a ferryboat in Washington state. That being said, I need to figure out which is the most stable way for me to park my bike on the ferry. I have spent the last two commutes in gutwrenching anxiety over the idea of my new baby falling over.
I have researched the web and this site, and so far have only come accross a forum on FJR's which addresses this problem specifically, however there seems to be a 50/50 concensus on which is the most stable.
I figure that on the side stand with it in first gear, I have a better chance of it not rolling forward and thus falling, but I'm just not sure, since my wing doesn't seem to lean as far over as my other bikes did. On the other hand, it weighs so much, that I'm sure the stability is helped with the lower center of gravity. I just don't know...
Thanks for the input!
"And I to my motorcycle
Parked like the soul of the junkyard
Restored, a bicycle fleshed
With power, and tore off
Up Highway 106, continually
Drunk on the wind in my mouth,
Wringing the handlebar for speed,
Wild to be wreckage forever."
CBW is offline
post #2 of 13 (permalink) Old 09-29-2008, 11:54 PM
Lil Pete's Avatar
When I crossed on a ferry I had it in gear, on the side stand, air shocks all the way up,and I was standing next to it holding the front brake. ...... Did the ferry thing twice .....
2008 GL1800B (Airbag)
Lil Pete is offline
post #3 of 13 (permalink) Old 09-30-2008, 01:02 AM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
No brainer, side stand all the way.
Either way, you have 3 points of contact with the ground. On the side stand, the 3 points are far apart. On the center stand, 2 of the point are only a foot apart.
What's more sturdy, a 3 legged stool with the 3 legs equally placed around the outside, or a stool with two of the 3 legs a few inches apart, and the 3rd leg on the opposite side?
Silicon Sam is offline
post #4 of 13 (permalink) Old 09-30-2008, 05:46 AM
Nightrider1's Avatar
Send a message via MSN to Nightrider1 Send a message via Yahoo to Nightrider1
Hello. I have to agree with Sam.
Nightrider1
You meet the best people who ride a Goldwing
Nightrider1 is offline
post #5 of 13 (permalink) Old 09-30-2008, 05:59 AM
Just one of the guys
DougW's Avatar
If the ferry hasTie down rings available a strap across the seat while on the side stand and she should be fine. If they don't have rings, you might ask the operator to put some in or you might find a post to strap the front tire to to be sue it won't roll about if things get bumpy.
Doug
DougW is online now
post #6 of 13 (permalink) Old 09-30-2008, 09:09 AM
Feetup's Avatar
Model: '84 1200 Int.
Send a message via AIM to Feetup
CBW;
I live on Vancouver Island, and the only way to get anywhere else is by ferry. I usually use B.C. Ferries, but there are others.
What almost all bikers do is to use the side stand, and shove one of those laminated wooden wheel chocks that they use to keep cars and trucks from rolling away, under the lowest point on the high side of the bike to keep it from going over on the high side. On the wing it will be the frame tube. You might have to stack two of them. On the B.C.Ferries they have special extra tall ones made just for the bikers. Remember that the ferry may lurch from side to side while docking, or if the seas get nasty, and it may stop suddenly when they hit thedock a little too agressively, but it will never accelerate quickly. Try to park your bike at an angle to the boat, or better yet at right angles with the high side towards what will be theback when they dock. Turn the front wheel all the way to the left so that if it rolls forward it will pivot around the side stand, not off of it.
As far as the center stand goes, I think you will find it nearly impossible to get the bike off the stand on the steel decking, especially if it is wet.
There are two kinds of fools: one says,"This is old, therefore it is good"; the other says,"This is new, therefore it is better." William Ralf Inge
Tim Johnson
\'84 GL1200I
\'75 GL1000
\'02 GASGAS Trials
\'56 Norton Dominator 600
Feetup is offline
post #7 of 13 (permalink) Old 09-30-2008, 10:08 AM
goldtop's Avatar
Model: gl1100 1980 mileage 150,000
I've seen a few motorcycle couriers use the hgv tie down straps that have hooks on each end. I suspect they were "Won" from the road side. They hook onto a solid object either side of the saddle and ratchet it down on the side stand. Then again Couriers have little respect for their body panels. Even saw one joker use a car as an anchor point. Now thats taking the P***s.
keep the old girl on the road
1980 gl1100 A canadian import. mileage 150,000 +
goldtop is offline
post #8 of 13 (permalink) Old 09-30-2008, 10:25 AM
William_86's Avatar
Model: GL1500 Aspencade
well both stands are pretty stable. but i would use side stand on gear. also using a velcro strap i would secure the front brake lever applied so it wouldn't roll forward
William_86 is offline
post #9 of 13 (permalink) Old 09-30-2008, 10:55 AM
EDDIE W's Avatar
side stand is the best way, and leave it in gear, turn your alarm off if you have one, cover the seat incase he throws his strap over it
GSVH
\'88 GL1500
EDDIE W is offline
post #10 of 13 (permalink) Old 09-30-2008, 11:20 AM
Bob W's Avatar
Side stand is designed to be more stable as long as the wheel is turned all the way to the left and locked. The Center stand is not as secure for side to side motions
2008 GL1800
\'81 GL1100
\'85 BMW K100rt
\'91 Nighthawk 750
None of my bikes make much noise.
veho illic quod tergum
Bob W is offline
Side stand or center stand oharaLTD General Motorcycle Discussion Forum 42 02-27-2011 06:09 PM
side stand or center... Tank4300 General Motorcycle Discussion Forum 27 02-23-2011 06:03 PM
Side stand or centre stand Harry Goldwing Technical Forum 3 05-26-2009 10:19 AM
side stand vs main stand griffd1 Goldwing Technical Forum 9 04-22-2008 02:20 AM
Center stand - Side stand Putt N along General Motorcycle Discussion Forum 8 04-19-2007 12:52 PM
