brake disc - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 10-11-2008, 07:04 AM Thread Starter
My brake disc has a high spot that the brake pad touches. You can hear it at low speeds. I have tried to take the lock nuts off but they just spin without coming off. Does anyone have a way to get them off? Oh by the way new nuts cost $2.95 at the stealers.
Alski [ Lord, please make me as good as my dog thinks I am!]
1987 Aspencade - Black
alski425 is offline
post #2 of 15 (permalink) Old 10-11-2008, 08:18 AM
Nightrider1's Avatar
Send a message via MSN to Nightrider1 Send a message via Yahoo to Nightrider1
Put a screwdriver under the nuts as you loosen them, and aply pressure downwards on the bolt, then afrer it rises a little, put a wrench under them. The other option is to use a hack saw and cut then off if you are going to replace them. Just don't cut the lines or rotor.
Hope this Helps,
Nightrider1
You meet the best people who ride a Goldwing
Nightrider1 is offline
post #3 of 15 (permalink) Old 10-11-2008, 10:33 AM
mikef's Avatar
Model: Aspencade
The bolts that hold the rotors on are long bolts and the heads can be found on the other side, on the other rotor. Two wrenches will do it.
Finally, old enough to know better. Just need some common sense now......
Patriot Guard Rider
1986 GL1200 Aspencade
1993 GL1500 Aspencade
1985 GL1200 Aspencade
1985 Suzuki Madura 700
1973 Honda 350CB
1965 Honda 50
mikef is offline
post #4 of 15 (permalink) Old 10-11-2008, 10:56 AM Thread Starter
Thanks a lot Mikif, I never looked at the other side, sure saves me a lot of grief, again thanks ALSKI
alski425 is offline
post #5 of 15 (permalink) Old 10-11-2008, 11:07 AM Thread Starter
Thats what is wrong with old age,you get stubborn and never look on the other side.
alski425 is offline
post #6 of 15 (permalink) Old 10-11-2008, 11:33 AM
EDDIE W's Avatar
i'm not sure if this applies to the aspy, i know it does for the interstate.
just make sure you put the bolts back in the way they off, meaning the head of the bolt to the right side and the nuts on the left side
GSVH
\'88 GL1500
EDDIE W is offline
post #7 of 15 (permalink) Old 10-12-2008, 09:57 AM Thread Starter
Sitting on the bike my rotor nuts are on the right side.
alski425 is offline
post #8 of 15 (permalink) Old 10-12-2008, 10:11 AM
EDDIE W's Avatar
ooops sorry, youre right, my mistake,
GSVH
\'88 GL1500
EDDIE W is offline
post #9 of 15 (permalink) Old 10-12-2008, 10:18 AM
mikef's Avatar
Model: Aspencade
I just looked at a spare wheel I have and the nuts would be on the left side, sitting on the bike. I'm not sure it makes any difference. The manual doesn't specify and as long as the rotors sit tightly against the wheel, I'm not sure it's an issue. IMHO.
Patriot Guard Rider
1973 Honda 350CB
1965 Honda 50
mikef is offline
post #10 of 15 (permalink) Old 10-12-2008, 10:45 AM
EDDIE W's Avatar
it does on the interstate mike,if you put the nuts on the left side it interferes with the speedo drive, i made that mistake,
its not the nuts as such, its the threaded part of the bolts that issticking out further than the nuts that catches the speedo drive
GSVH
\'88 GL1500
EDDIE W is offline
82' Aspencade rear brake disc. BikerGRG Goldwing Technical Forum 2 10-02-2012 07:27 PM
Rear Brake Disc John J Goldwing Technical Forum 2 10-10-2011 07:40 AM
Rear Brake disc replacement kittykathy Goldwing Technical Forum 3 05-12-2009 09:25 AM
rear brake disc TXRLGL1500 Goldwing Technical Forum 7 03-30-2009 11:08 PM
86 Interstate-rear brake disc 2whlrider For Sale/Wanted Forum 1 08-24-2006 12:59 PM
