78 gl1000 main fuse burnt in two - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 11-22-2008, 05:52 PM Thread Starter
morriscatt's Avatar
Year: 1981
Make: Gl-1100
Model: Standard
Hello all again,
just put air cleaner back on before riding, started, died couple times seemed weird, started again, revved it up and got to end of drive when died again. pushed back home cause when switch on no red light/neutral light and hitting started switch did nothing. Found main fuse burnt in two. just for grins if put a ink pen spring in place of the main fuse, simply turned on switch and it burnt in two.
my guess would be that air cleaner box shorted out against the resistor on right coil.
considering I just got it running great before this,
Should I assume that there is a short that caused main fuse to burn out??
Patrick Morrissey (Go Irish)
Started on family owned Cushman Scooter
First Bike was a 1967 Riverside 125cc
Dad\'s 78 GW ashes.
Bringing another 1100 back to life, rising from the ashes of my 1000... Thanks to this forum!
"Enjoy the Ride"
morriscatt is offline
post #2 of 9 (permalink) Old 11-22-2008, 06:03 PM
Big Cahuna's Avatar
Might just be that its 30 years old and needed a break.,,
Bikes Ive owned, \'69 Norton,\'48 Harley panhead, \'71 Bsa, \'76 gl1000,\'93 Harley ultra,\'03 Harley ultra,\'05 Sportster, \'82 GW 1100.\'96 Police road king very used. "I tried thinking once, but nothing happened" .,,,
Big Cahuna is offline
post #3 of 9 (permalink) Old 11-22-2008, 06:07 PM
If a fuse burns out (or blows)it is logical to assume something overloaded (shorted out) it. Look for wires pinched from what you were just working on.
post #4 of 9 (permalink) Old 11-22-2008, 07:29 PM
Passed On, R.I.P.
Bagmaster's Avatar
I'll go with the old age gambit on this one too.
Michael
USS Saratoga, ships company
Bagmaster, our former forum Toolmaster and friend, is no longer with us. He passed away in February 2012.
The roads and byways, no matter how beautiful and exhilarating, are a lonelier place now. RIP Bagmaster (Baggy).
Bagmaster is offline
post #5 of 9 (permalink) Old 11-22-2008, 07:56 PM Thread Starter
morriscatt's Avatar
Year: 1981
Make: Gl-1100
Model: Standard
So R U saying the fuse was just old and worn out.. What about it burning the ink pen spring in 1 second with only the switch on? Only being curious before I tear into it tomorrow.
Dad\'s 78 GW ashes.
"Enjoy the Ride"
post #6 of 9 (permalink) Old 11-22-2008, 08:08 PM
mikef's Avatar
Model: Aspencade
What about checking for a pinched wire, then trying again, only this time with a real fuse?
Finally, old enough to know better. Just need some common sense now......
Patriot Guard Rider
1986 GL1200 Aspencade
1993 GL1500 Aspencade
1985 GL1200 Aspencade
1985 Suzuki Madura 700
1973 Honda 350CB
1965 Honda 50
mikef is offline
post #7 of 9 (permalink) Old 11-22-2008, 08:21 PM Thread Starter
morriscatt's Avatar
Year: 1981
Make: Gl-1100
Model: Standard
I looked around for pinched wires, have not found any. I am curious if anyone else has had a short between the Air cleaner body and the right coil resistor? I can see a spot on the right side of the coil where something has been rubbing for a while. almost a hole there. I am thinking the nose of the air cleaner body has been pushing against the resistor and it in turn has rubbed on the coil,,
the only thing I did today prior to riding was putting the air cleaner & Air cleaner body back in.
Update: it was shorting out against the resistor. I glued on some rubber hose to the nose end of air box and will try putting back in tomorrow.
Thanks to all who read and replied. Guess I am gonna use a plastic tie to tie the resistor up also.
Dad\'s 78 GW ashes.
"Enjoy the Ride"
post #8 of 9 (permalink) Old 11-24-2008, 08:22 AM
age.... been there done that
however, on a wing of our "olde-wings" age, does it hurt to clean and check all of connectors? actually, it is a very good idea.....
did someone mention belts?
rcmatt007 is offline
post #9 of 9 (permalink) Old 11-24-2008, 09:58 AM Thread Starter
morriscatt's Avatar
Year: 1981
Make: Gl-1100
Model: Standard
Hey Rodger,
Happy Thanksgiving to you and yours. Thanks for the response.. In order to drive the bike home from Kansas where I got it, I had to cap 3 of the main wires cause they were burnt in the connector. I still need to do more of the cleaning you mentioned. Dingdong and others have given me the old evil eye about not doing the belts yet. That (hopefully) will be my next project. I was online last night checking prices. $16 +postage at Rockauto... I hope to find them for a reasonable price locally however. I need to go to the auto store anyway cause she started running out of gas yesterday because the fuel filter is plugged up a little. She won't run fast for long, but when I stopped and let her rest a minute, or even just slow down for a minute she picks back up.. I almost got depressed when the fuse blew, however as soon as I put the new edge holder and fuse in (and removed the Air Box) and she started right up, I was smiling again.. Thanks again Rodger, hope to meet some day.
Dad\'s 78 GW ashes.
"Enjoy the Ride"
where to get main metal fuse for your main electrical system gpmillwright Goldwing Technical Forum 21 01-21-2010 08:21 AM
Main Fuse Rod Goldwing Technical Forum 16 05-24-2009 07:11 PM
main fuse pj New Members Introduction Forum 6 07-21-2008 03:27 AM
GL1000 1978, Main fuse melting ran429 Goldwing Technical Forum 4 02-18-2005 09:59 AM
Main Fuse LesTension Goldwing Technical Forum 3 07-18-2004 07:30 AM
