How to Measure oil level when installing Progressive Springs? - Page 2 - Steve Saunders Goldwing Forums
post #11 of 11 (permalink) Old 04-18-2009, 02:55 PM
Cal-D's Avatar
Model: Stream Silver 2007
When Progressive talks about oil level, they are refering to excessive levels, like 3-4 inches high or low. Honda recommends a level of 5 inches for an 1800 and progressive lowers that by a half inch due to their larger springs displacing more oil. Lowering the oil level by a half inch or even an inch will have no affect. Lowering too much and you will cavitate on large bumps(air in oil) and the suspension will be very mushy. Too high a level will creat a hyd lock on compression and blow the seal.
Have Wing Will Travel
Cal-D is offline
10 or 15 wt fork oil with progressive springs SmartBiker Goldwing Technical Forum 4 05-17-2012 10:10 AM
installing progressive front fork springs mccoyrg43 Goldwing Technical Forum 10 06-17-2011 07:58 PM
Installing Progressive Fork Springs on a GL1500 SE OldHDRider Goldwing Technical Forum 22 04-16-2011 04:09 AM
Another question about installing progressive springs, GL1500 Reinyrooster Goldwing Technical Forum 22 09-05-2010 11:07 AM
Installing progressive fork springs racertim Goldwing Technical Forum 2 05-01-2010 07:46 PM
