Starter Or Battery? - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 04-16-2009, 09:07 AM Thread Starter
Wingman1125's Avatar
Good morning everybody,
This morning I went out to start my 82 1100 and when I hit the trigger it acted like it was a dead battery. I put it on the charger for 1 hour. Came back out. Nothing. Tried to jump it with the charger. Nothing. Pulled it out of the garage pushed and held the button a couple times and it finally started cranking. Is it a bad Battery or Starter taking a crap?
Jason
Wingman1125 is offline
post #2 of 10 (permalink) Old 04-16-2009, 09:14 AM
98Wing-487's Avatar
SPECIAL EDIT..... READ THIS WHOLE THREAD
I'd check the cables first. Remove them, the ground side too,and make sure that they are clean and tighten them back up. If that doesn't do it, you may want to check the fuses, starter button, etc.
Last year, I had a problem with my bike not starting. I searched and searched, troubleshooting every electrical component....only to find that my 9 month old battery had taken a dump. It had 13 volts but no amps. Go figure. I've got a good sealed battery now...not the Yuasa from Wally World.
Without a ride...for now.
98Wing-487 is offline
post #3 of 10 (permalink) Old 04-16-2009, 09:14 AM
plainmech's Avatar
i would start by checking bat. voltage and contacts for corrosion ect. also perform load test on bat., if you don't have a load tester most parts stores will do it for free
87 Aspencade Use it up, wear it out, make it do, or do with out
Proud member of Texas Wild Rhinos
plainmech is offline
post #4 of 10 (permalink) Old 04-16-2009, 02:27 PM
Wichita Scorpion's Avatar
Send a message via AIM to Wichita Scorpion
Suggest that you check the dog bone 30 amp fuse if you haven't replaced it with a by-passed plug in fuse/fuse holder. I had same problem last year, everything worked except the starter. Dog bone fuse fell to pieces when removed.
Keith
Wichita Scorpion is offline
post #5 of 10 (permalink) Old 04-16-2009, 02:31 PM
Olegrumpy's Avatar
The load test at the parts house ain't always right. Last fall mine went dead every third day and they load tested it and said it was good. One more week of a dying battery and I got a new one and have not had a problem since.
Any day above ground is a good day.
Olegrumpy is offline
post #6 of 10 (permalink) Old 04-16-2009, 08:40 PM
FWIW, mine does the same thing on initial startup. Press the button, lights dim...nothing. Two seconds later it finally starts. I was told the starter switch might need cleaning. I also suspect my starter needs a good rebuild and cleanout.
Now once it's warmed up the starter hits right away, soon as I press the button.
chris in va is offline
post #7 of 10 (permalink) Old 04-16-2009, 10:04 PM
Send a message via Yahoo to vedgar
The starter comes out easy. Clean up the armature of the starter and then try. If the battery voltage drops below 10.5 volts while cranking , I would suspect the battery. Good starting involves more than one component.
81 GL1100 standard (Cosmo Black)Rockin !
76 Honda 750F supersport Rockin !
74 BMW R75/6 Rockin !
79 Yamaha XS1100 Special Rockin !
vedgar is offline
post #8 of 10 (permalink) Old 04-17-2009, 07:21 AM Thread Starter
Well Thanks everybody,
I now have a direction as to what I'm going to do. I appreciate the Help
Jason
post #9 of 10 (permalink) Old 04-18-2009, 01:30 PM
daz800's Avatar
problem with gl1100 is the brushes in the starter motor. if you replace them it should sort out your problem.. its a known fault
Daz
wife and i have a 50/50 system...i fill up the car and she drives it..
daz800 is offline
post #10 of 10 (permalink) Old 04-18-2009, 01:36 PM
rb7632's Avatar
Year: 2006
Model: GL1800A
I have experienced the same problem with my 81 1100.
I found that only holding in the clutch to start will sometimes cause this if you don't have the transmission in neutral. I even went to the point of replacing the starter. Same problem.
If I am in neutral AND hold in the clutch, no problems.
Brotherhood of Grey Beard Bikers
GWRRA, Region E, Chapter Z
1800 Darkside Riders #1094
Michelin Primacy Alpin PA3 ZP 195-55-16
Patriot Guard Riders
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... Wow--What a ride!"
rb7632 is offline
Battery or Starter? Swaggerman Goldwing Technical Forum 11 06-08-2009 04:20 PM
What's the best battery/starter trouble? Evil twin Goldwing Technical Forum 4 12-16-2007 06:47 AM
Battery ??? Starter ??? bgonz General Motorcycle Discussion Forum 19 11-29-2007 06:59 PM
Starter/battery issue LD Hack Goldwing Technical Forum 7 10-18-2007 07:45 PM
battery or starter snowy Goldwing Technical Forum 4 05-24-2007 08:37 AM
