Acc. terminal - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 04-16-2009, 06:32 PM Thread Starter
chiefcherokee's Avatar
Was hooking up driving lights, hooked up the power to a wire I've got running my power point from the accessory terminal and suddenly I've only got .5 volts from the terminal. Tested at the wire and the terminal itself. Any ideas?
Randy
I say more dumb &#!* before noon than most people say all day.
SE Texas Patriot Guard member
chiefcherokee is offline
post #2 of 13 (permalink) Old 04-16-2009, 07:03 PM
Wichita Scorpion's Avatar
Send a message via AIM to Wichita Scorpion
Sounds like the Accessory Terminal Fuse is blown. Should be fuse #1 (5 amp), located at the top of the fuse block. Fuse #1 only supplies power to the screw terminals for aftermarket connected items. Accessory Fuse #10 (10 Amp) supplies power to other OEM wired in accessories.
Connections for driving lights should be connected to the battery withan inlinefuse andrelay. Control the relay with a on/off switch connected to the Accessory Terminal.
Keith
Wichita Scorpion is offline
post #3 of 13 (permalink) Old 04-16-2009, 08:51 PM
Cal-D's Avatar
Model: Stream Silver 2007
If you are using the acc terminal for driving lights, DON"T !! They draw way too much power for that circut to handle. Driving lights should be wired direct from the battery through a relay, you can trigger the relay using the Acc terminal.
Have Wing Will Travel
Cal-D is offline
post #4 of 13 (permalink) Old 04-16-2009, 09:10 PM
Snorebaby's Avatar
This is how I done my driving lights. Works great. Plus the fuse block has 6 places for fuses....I have expansion room!!!
'15 GL1800 Scarlett
'90 GL 1500 SE Pearl
'86 CMX450 Rebel
'85 GL1200 LTD---SOLD
Patriot Guard Riders #137660
Snorebaby is offline
post #5 of 13 (permalink) Old 04-16-2009, 09:16 PM Thread Starter
Thanks for the replies. I really appreciate the diagram Snorebaby, makes things much more clear.
Randy
post #6 of 13 (permalink) Old 04-16-2009, 09:33 PM
Snorebaby's Avatar
No problem....I also wired in a single LED on the Light side of the switch to let me know if they are on or off......But you don't have to....when you turn thekey to theoff position, the lights will go off.
'15 GL1800 Scarlett
'86 CMX450 Rebel
post #7 of 13 (permalink) Old 04-16-2009, 11:07 PM
Snorebaby,most peoplenormally recommend placinga fuse within six inches of the battery positive post and before any load, including the relay.Should the relayshort out internally, probably dead battery, quickly.
No argument, just another input.
Keith
post #8 of 13 (permalink) Old 04-17-2009, 02:45 AM
Snorebaby's Avatar
WS....excellent suggestion...I had forgotten about that as my relay is actuallyfused.I had a relay laying around that has a 15ampATC fuse on it. That is the one I used forthe wiring ofmyfuse block.
I have had that same thing happen to me.
'15 GL1800 Scarlett
'86 CMX450 Rebel
post #9 of 13 (permalink) Old 04-17-2009, 08:13 AM
Hawker22's Avatar
Snorebaby--I also have one of those acc. panels on the side of my battery. I am studying your diagram, and for the life of me, I can't seem to figure it out. It looks like when you power the relay on the left, it will short out the battery-(join the pos and neg terminals). But I DO see how you used that panel to power the switched driving lights.
Am I out in left field?? and if so, can you please explain.
Hawker22(Ken)
Per Ardua Ad Astra
1997 GL1500SE--White Cloud
2001 GL1800----Blue Yonder
Hawker22 is offline
post #10 of 13 (permalink) Old 04-17-2009, 11:58 AM
Snorebaby's Avatar
Hawker22....the "wiring" of the relay is just for information and not the actual position on the relay itself ...but the wires and where they are connected (numbers on the relay)is correct.
The drawing was done so my wires didn't cross and made it look cleaner. If you connect it following the numbers, you will have it wired correctly.
'15 GL1800 Scarlett
'86 CMX450 Rebel
Headset Terminal MDBKER Goldwing Technical Forum 4 04-08-2012 02:26 PM
Terminal Cliff Jumping pinkpork Miscellaneous Forum 19 01-16-2009 06:11 PM
Fried battery terminal maplewingnut Goldwing Technical Forum 19 09-03-2008 10:00 PM
AC terminal limits DigbyODell Goldwing Technical Forum 6 06-25-2007 06:37 AM
wire terminal sizes mag Goldwing Technical Forum 9 03-26-2005 11:59 AM
