My Fairing Bubbles? - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 04-24-2009, 07:54 AM Thread Starter
IBA Member
Kefltrvlr2's Avatar
Model: GL1200A, 2014 FLHTK Ultra Limited
Caught my first rain storm last night with my new wing. Kind of odd to see air bubbles blowing out between the inside of the windshield and the top of the dash. Looks like I'm tearing it apart Saturday. Any advice?
Screw it, Let's ride!
When life throws you a curve.....lean into it!!!
Kefltrvlr2 is offline
post #2 of 8 (permalink) Old 04-24-2009, 07:58 AM
RayandTracy's Avatar
Is the dash/widshield matt/seal rightside out? Also is everything nice and snug?
Please let us know what you com up with.
Ride Safe, Ray
RayandTracy is offline
post #3 of 8 (permalink) Old 04-24-2009, 09:24 AM
Mine will do that once in a while. If the wind is right I suspect. It isn't bad and doesn't hurt anything so it doesn't bother me.
post #4 of 8 (permalink) Old 04-24-2009, 09:51 AM Thread Starter
IBA Member
Kefltrvlr2's Avatar
I'm suspecting things are loose cuz the windshield rattles around a lot over 50mph. Previous owner must have not put it back together correctly.
post #5 of 8 (permalink) Old 04-24-2009, 09:56 AM
Pretty simpple to remove and inspect the 4 bolts/screws that hold the windshield on.
If loose it wouldn't be good for windshield to the moving around and possibly cousing 20+ year old plastics to crack from not being tight, just thoughts on this.
Ride Safe, Ray
post #6 of 8 (permalink) Old 04-24-2009, 07:14 PM Thread Starter
IBA Member
Kefltrvlr2's Avatar
Ride Safe, Ray
Turns out to be nothing major. Screws for the windscreen were a little loose. Thinking about running a bead of sealant between the screen and rubber gasket then gasket to dash.
post #7 of 8 (permalink) Old 04-24-2009, 08:14 PM
johnnynogood's Avatar
Be careful of what type of sealant you use. Some have chemicals that will attack the Plexiglass, might make it milky looking.
If you get scared half to death twice, would you be dead?
johnnynogood is offline
post #8 of 8 (permalink) Old 04-24-2009, 09:28 PM
You shouldn't need a sealant. Once you get things where you want them, push the gasket/mattin a bitbefore you tighten the windshield down. That makes a tighter seal.
Using a sealant you run a risk of damagingthe gasket, as well asthe dash board and the windshield.
Dolphin bubbles Fritz_The_Cat Miscellaneous Forum 9 11-19-2010 11:41 PM
Bubbles on front tire DrifterTex Goldwing Technical Forum 29 05-24-2010 09:45 AM
Exhaust bubbles in the radiator holly609 Goldwing Technical Forum 10 06-07-2009 04:14 PM
Bubbles and Barbie... retiredintime Fun Forum 0 06-07-2008 01:48 PM
gl1100 brake bubbles hossners Goldwing Technical Forum 6 04-14-2008 11:59 AM
