Spark Unit - Steve Saunders Goldwing Forums
post #1 of 19 (permalink) Old 05-04-2009, 07:47 PM Thread Starter
Hiram's Avatar
Send a message via Yahoo to Hiram
Having trouble with rough running on one side -just put new belts on. got to looking around around and found the spark unit had melted in half. May be my problem but what would cause this to happen
PGR Rider
Past Master
AMVETS,Post Adjutant, District 2nd Vice
Proud American!
Hiram is offline
post #2 of 19 (permalink) Old 05-04-2009, 08:04 PM
It may be one of those things that just happens or a shorted coil is possible.
post #3 of 19 (permalink) Old 05-04-2009, 10:24 PM
Piled Higher and Deeper
sandiegobrass's Avatar
Common problem, particularly on early 1100s. The ballast resistor is internal to the spark units and melts the boxes.. But just melted doesn't make it quit.. most keep on ticking... although excessive heat could eventually cause it to fail... later 1100s put the ballast resistor outside the boxes (but left the unused one inside) and reduced the problem greatly.. SDB/Jim
AKA "Jim"
Have a Gold Wing? Look at the
! even though they closed this one it has the best graphics and is valid.
2000 GL1500SE
1983 GL1100I
But formerly San Diego, Terra Haute, Aiken, Oak Ridge, Tonopah NV, Pasadena CA, Aiken SC, Richland WA, and now back to Tonopah NV..)
sandiegobrass is offline
post #4 of 19 (permalink) Old 05-04-2009, 10:48 PM Thread Starter
Hiram's Avatar
thanks- so I take it this probraly doesnt have anything to do with a cylinder not hitting right
PGR Rider
Past Master
Proud American!
Hiram is offline
post #5 of 19 (permalink) Old 05-04-2009, 11:40 PM
mdbauer1962's Avatar
Hiram,
Is this how your spark units looked? These are from my 1980 GL1100. They heat up, and the black goo seeps out. I'm told that this is just a factor of heat and time on the older 1100's. Just clean them up as best you can, and fill up the back areawith the clear epoxy you find for $5 or so at WalMart. Good as new !!!
Each unit runs (2) cylinders, so if they were bad, it would take out both. Not likely your running problem.
Life is too short - Live like today is your last day on earth!!! If I go to my maker with a few bumps and bruises, it just means I took the scenic route!
mdbauer1962 is offline
post #6 of 19 (permalink) Old 05-05-2009, 10:43 AM
wda-83wing's Avatar
Model: 83 GL 1100 I
nice pics and explanation too .
wda-83wing is offline
post #7 of 19 (permalink) Old 05-05-2009, 11:12 AM Thread Starter
Hiram's Avatar
that is exactly hoe they look!
PGR Rider
Past Master
Proud American!
Hiram is offline
post #8 of 19 (permalink) Old 05-05-2009, 11:22 AM
wda-83wing's Avatar
Model: 83 GL 1100 I
now--you know what to do .
post #9 of 19 (permalink) Old 05-05-2009, 06:25 PM Thread Starter
Hiram's Avatar
was at the honda shop today -thought i would just replace if part was reasonable -185.00 guess i'll be doing the epoxy trick!
PGR Rider
Past Master
Proud American!
Hiram is offline
post #10 of 19 (permalink) Old 05-05-2009, 08:09 PM
wingd's Avatar
You can find them on ebay for a 1/4 the price of new.
1981 GL1100S 2010 GL1800 Titanium
Wingd
wingd is offline
gl 1100 spark unit crowesnest3 Goldwing Technical Forum 18 08-18-2010 09:57 PM
ignition amplifier/spark unit johny.b Goldwing Technical Forum 6 03-28-2009 01:06 PM
spark unit Gl1100 fliptat Goldwing Technical Forum 6 06-11-2006 05:00 PM
Replaced the Spark Unit ... still no spark ttexastim Goldwing Technical Forum 14 06-06-2006 04:15 AM
Spark Unit on 1980 GL1100 ARKnapp Goldwing Technical Forum 4 08-22-2005 02:59 AM
