83 1100a rotors - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 05-06-2009, 12:09 AM Thread Starter
Put Put's Avatar
hi peoples . I have a 83 1100a with 80 k . It has been rode hard &put away wet . I must thank you for letting me join, with your help i can keep it on the road . My question is how do you measure the front rotors for thickness? Rather be safe than sorry. Any help would be apprecated.wayne
previous bikes 650 bsa cb 400a cb 750k
Put Put is offline
post #2 of 4 (permalink) Old 05-06-2009, 05:12 AM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
Measure the thickness right across and including the vented part.
Alan Fitzpatrick.
FitzAl is offline
post #3 of 4 (permalink) Old 05-06-2009, 05:00 PM Thread Starter
Put Put's Avatar
Thanks FitzAl For the help . The p. o. did nothing for maintence. I just got the bike ,change all fluids. Checking the rest of the bike over.
Put Put is offline
post #4 of 4 (permalink) Old 05-07-2009, 12:10 AM
Guru
Hatchetman's Avatar
Minimum thickness should be stamped in the rotor. You need ten thousands of an inch more than that to turn them. If you have any nasty grooves, you will need more room. If you buy replacement rotors make sure they have holes in the brake surface area for water displacement.
Hatchetman is offline
My new to me 1100A oharaLTD Goldwing Technical Forum 32 07-27-2011 08:32 PM
Gl 1100a Radio jaywalls New Members Introduction Forum 14 04-30-2011 04:08 PM
83 1100a Put Put Goldwing Technical Forum 8 05-25-2009 01:04 AM
GL 1100A 8thdwarf Goldwing Technical Forum 2 08-06-2008 06:53 PM
GL 1100A with Sidecar Wichita Scorpion Goldwing Technical Forum 4 01-01-2008 07:37 PM
