Stainless Steel brake lines - Steve Saunders Goldwing Forums
View Poll Results: Stainless steel brake lines
Have you ever had a cataclysmic rubber brake line failure on your GL1200? 1 14.29%
Do you know of any rider having the same on any bike? 0 0%
If you did, at what mileage did this happen? 0 0%
20,000M 0 0%
30,000M 0 0%
50,000M 0 0%
100,000 or over 0 0%
Have you changed your brake lines to Stainless steel and if so what make? 6 85.71%
Why did you change them? 0 0%
Voters: 7. You may not vote on this poll
post #1 of 22 (permalink) Old 05-11-2009, 04:49 PM Thread Starter
tricky's Avatar
Year: 1985
Model: 85 Aspencade
I imagine that one would feel a change in the braking of the motorcycle if one changed to stainless steel lines.
Does anyone have any comments?
tricky is offline
post #2 of 22 (permalink) Old 05-11-2009, 04:57 PM
On cars, the change over from rubber caused the "feel" to change from "soft and spongy" to "hard and at the top" of the pedal.
post #3 of 22 (permalink) Old 05-11-2009, 07:15 PM
ali
ali's Avatar
I would agree with AZgl1500, in theory there should be less flex or expansion in the brake hoses applying more pressure to the pistons.
if at first you dont succeed, then maybe failure is your thing!
ali is offline
post #4 of 22 (permalink) Old 05-11-2009, 07:59 PM
I've never had a problem with a brake line on any vehicle, ever.
I am considering new lines on my GL12, but if I do change them, it will be OEM. They fit better and last forever. I would probably notice some difference in immediate bite but overall I wouldn't expect them to change braking distances. It's quite easy to bring the tires to the brink of lock-up now.
post #5 of 22 (permalink) Old 05-11-2009, 08:05 PM Thread Starter
tricky's Avatar
Year: 1985
Model: 85 Aspencade
I have never had a problem with rubber brake lines either, I'm just trying to find out if anyone has. Yes I can lock the brakes on my 1200 too. with the 25 year old lines.
Are you not concerned that your new OEM rubber lines might have been stored in a warehouse for 25 years... Just a thought?
That was the way it was put to me.
tricky is offline
post #6 of 22 (permalink) Old 05-11-2009, 08:09 PM
GSMacLean's Avatar
It made the "bite" area of my brakes much sharper and more precise. Instead of a gradual spongy "from here to here is where the brakes engage" (as if it had air in the system), it is a very sharply defined "brakes off here, brakes start engaging HERE". It's quite reassuring and I think makes it much easier to modulate the brakes. I would definitely never go back to rubber lines after experiencing the stainless ones.
Read my
GSMacLean is offline
post #7 of 22 (permalink) Old 05-11-2009, 08:24 PM
dan filipi's Avatar
Model: 1983 GL 1100 I
Ditto exactly.
dan filipi is offline
post #8 of 22 (permalink) Old 05-12-2009, 06:11 AM Thread Starter
tricky's Avatar
Year: 1985
Model: 85 Aspencade
WHich make of Stainless lines did you purchase?
tricky is offline
post #9 of 22 (permalink) Old 05-12-2009, 07:14 AM
GSMacLean's Avatar
I bought VencoWings lines. I did a lot of research online, and every ad-hoc "pick and choose your parts" vendor I found, once you added up all the things that were included in the VencoWings kit, came very close to the VencoWings price...so I just bought their kit, which came with everything I needed, and all lines sized for my bike.
Read my
post #10 of 22 (permalink) Old 05-12-2009, 07:20 AM Thread Starter
tricky's Avatar
Year: 1985
Model: 85 Aspencade
What list of things would be needed other than the lines?
I can see any things on the actual OEM lines which would be required.
tricky is offline
Replacing GL1500 brake lines with stainless steel lines jlbc212 Goldwing Technical Forum 15 01-21-2013 11:03 AM
1500 Stainless Steel Brake Lines HogansWing Goldwing Technical Forum 5 01-09-2010 06:10 PM
Stiff Stainless Steel Brake lines sandcastcb750 Goldwing Technical Forum 1 05-28-2009 05:27 PM
Stainless Steel Brake Lines toy4rick Goldwing Technical Forum 5 09-14-2008 05:44 AM
Stainless Steel Brake Lines 82 GL1100I atgattrat Goldwing Technical Forum 3 10-21-2006 01:55 AM
