gear ratio - Page 2 - Steve Saunders Goldwing Forums
post #11 of 17 (permalink) Old 05-14-2009, 02:33 PM
Nope Bagmaster, that would just make his problem even worse than it is. The 4.25 means the engine has to turn 4.25 times faster than the axle for a given wheel rpm.
A larger tire would reduce the effective axle ratio closer to the desired engine rpm for a given road speed. But as he already said, the required tire size would be monstrous.
post #12 of 17 (permalink) Old 05-14-2009, 02:40 PM Thread Starter
skoto1's Avatar
correct. 30" tall tires would give me a ground speed of 53 mph at 2100 rpm i could live with that but even at 30 in's the tries are too tall. i guess i'll just start over with another rear end i want have to scrap what i made just rewld up everything to the new rear end. anybody got a alfa ring gear laying around
PGR # 190570
cc permit
1988 1500 trike to be
1980 cb900 custom
gl 1988 1500 trike sold
2003 flhtuci sold
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
skoto1 is offline
post #13 of 17 (permalink) Old 05-14-2009, 08:54 PM
If you use an S-10 rear end make sure it's the one from a v-6 4.3 because the ratio will be 3.73. If you use the 4cyl S-10 the ratio will be 4.10 and I think thatis what you are trying to avoid. Even the 2.8 v-6 will probably be geareds to low for you.
When it\'s over your head it\'s under GOD\'S feet.
gotta love the wing is offline
post #14 of 17 (permalink) Old 05-14-2009, 09:07 PM Thread Starter
skoto1's Avatar
i'm looking for a mustang 4 lug now as i have already purchased the wheels that happen to be 4 lug. still trying to figure out how i can use what i have. transmisson guy told me to use and old 3 speed and turn it around put it in between the motor and rear end and put it in second gear he said that would make everything ok? may give it a shot i can pick one of them up for about 30 bucks.
PGR # 190570
cc permit
1980 cb900 custom
2003 flhtuci sold
skoto1 is offline
post #15 of 17 (permalink) Old 05-14-2009, 09:09 PM Thread Starter
skoto1's Avatar
oh by the way 373 will still be to high need more like a 300 or 290 as it had a 283
PGR # 190570
cc permit
1980 cb900 custom
2003 flhtuci sold
skoto1 is offline
post #16 of 17 (permalink) Old 05-14-2009, 11:23 PM
skoto1 wrote:
..........transmisson guy told me to use and old 3 speed and turn it around put it in between the motor and rear end and put it in second gear he said that would make everything ok?
That would give you the option of a really low gear if you decide to climb some heavy hills with a trailer behind you
flip it into low gear, and you have instant over-drive..
post #17 of 17 (permalink) Old 05-14-2009, 11:38 PM Thread Starter
skoto1's Avatar
or filp it up into third and eat the desert up. may give it a shot. just have to make it a little shorter than stock. take the tail shaft off and saw the input shaft back some. it's worth a try. here goes.
PGR # 190570
cc permit
1980 cb900 custom
2003 flhtuci sold
skoto1 is offline
Gear Ratio difference 81-82 Rumple Goldwing Technical Forum 12 03-19-2012 12:40 AM
Another gear ratio question dan filipi Goldwing Technical Forum 9 10-03-2011 10:39 PM
Gear ratio Nightrider1 Goldwing Technical Forum 12 11-11-2010 11:22 AM
1800 gear ratio kenracer Goldwing Technical Forum 2 09-22-2008 10:26 AM
Gear ratio question dan filipi Goldwing Technical Forum 6 10-26-2006 12:00 PM
