stebel horns - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 05-14-2009, 10:41 PM Thread Starter
Searchin's Avatar
I have a used set as pictured, tm80. Is there polarity to these?
The chains of yesteday surround me...
"Democracy without respect for individual rights is wrong. It’s just ganging up on the weird kid, and I’m always the weird kid."
Searchin is offline
post #2 of 15 (permalink) Old 05-14-2009, 11:14 PM
If there is, there should be a + sign and a - sign next to the terminals.
If there is only one post, that one is postive. The case will be ground or battery negative.
post #3 of 15 (permalink) Old 05-14-2009, 11:43 PM Thread Starter
Searchin's Avatar
I checked again, and mine are 90's, not 80's but pretty much the same. No polarity markings.
Searchin is offline
post #4 of 15 (permalink) Old 05-15-2009, 12:56 AM
Wichita Scorpion's Avatar
Send a message via AIM to Wichita Scorpion
Sometimes the + and - are stamped directly ona terminal. Otherwise check with Ohm Meter and see if either terminal is a short to the mounting bolt. If it is that is the -.
Keith
Wichita Scorpion is offline
post #5 of 15 (permalink) Old 05-15-2009, 01:01 AM Thread Starter
Searchin's Avatar
good information. thankyou.
Searchin is offline
post #6 of 15 (permalink) Old 05-15-2009, 01:13 AM Thread Starter
Searchin's Avatar
i saw a listing on ebay tonite that looks similar to mine. they say they sell it with a 30 amp relay. mine didnt come with a relay. whats the purpose of that relay? do I need one?
tech specs on the 80's (similar) show a draw of 11 amps at 12v.
Searchin is offline
post #7 of 15 (permalink) Old 05-15-2009, 01:35 AM
Yes, you will need a relay. The horn wiring, including the horn button switch, will not take the amperage the Stebel horns will draw. YourOEM wiring will control the relay.
You can get a 30 amp relay and a 20 amp fuse/fuse holder at any auto parts stores. Normally mount the fuse holder within 6 inches of the battery.
See this for correct connections:
Click Here-Bikerhiway Horn Installation
Did you get the +and - figured out?
Keith
post #8 of 15 (permalink) Old 05-15-2009, 01:51 AM
East_Winger's Avatar
I believe that is no polarity for this horn. I'm using TM80 too.
East_Winger is offline
post #9 of 15 (permalink) Old 05-15-2009, 05:15 AM
Monkey with a Football
Rudy's Avatar
Try it both directions.
One will be louder than the other.
Use the loud connection.
Rudy
...and the rabid dog they gave me
wasn't too much fun
Rudy is offline
post #10 of 15 (permalink) Old 05-15-2009, 10:50 AM Thread Starter
Searchin's Avatar
the 90's only pull 11a. why would I need a 30 amp relay?
Searchin is offline
Stebel Junior pump for air horns (off an 83 GL1100 Interstate) RckRagman For Sale/Wanted Forum 3 01-15-2012 08:13 AM
Stebel Horn SailorKane Goldwing Technical Forum 11 08-18-2009 06:18 PM
Stebel Nautillus horns Phils a winger at last General Motorcycle Discussion Forum 6 01-09-2008 09:55 AM
Stebel TM80 Magnum Dual Horns Snorebaby For Sale/Wanted Forum 9 10-06-2007 06:47 PM
Stebel Air Horns miles.from.nowhere General Motorcycle Discussion Forum 42 06-12-2007 12:09 AM
