Engine Ticking after bringing back to life - Steve Saunders Goldwing Forums
post #1 of 31 (permalink) Old 05-18-2009, 07:47 PM Thread Starter
'96 GW has been sitting for 2 years - I've been methodically bringing it back to life. It finally started idling this afternoon but is running rough. I'm getting a very audible ticking sound from the #1 cylinder (or close to it) and the engine seems to be missing. It runs up - but haven't had it over 2500rpm until this problem gets solved.
Help me out guys - any ideas?
Thanks!
TEXGWNUBE is offline
post #2 of 31 (permalink) Old 05-18-2009, 08:48 PM
Shooter's Avatar
Model: 2006 ST 1300
No real experience with the 6-cyls, but you might check to see if the plug wire/cap isn't isn't shorting to ground for #1 cylinder.
1986 Interstate, 2006 ST 1300
Shooter is online now
post #3 of 31 (permalink) Old 05-18-2009, 11:16 PM
Guru
Hatchetman's Avatar
Might be an idea to pop off that valve cover & confirm that all valves are opening & closing all the way. you might have a sticky one there. Could also be a noisy lifter.
Check your valve adjustment.
Hatchetman is offline
post #4 of 31 (permalink) Old 05-18-2009, 11:41 PM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
If it's been sitting that long it's possible that one or more of the HVA (hydraulic valve adjuster) has bleed down and needs to be pumped back up. This requires a special tool that you use to bleed the air out of the HVA. There is also a shimming process that is required but if you haven't removed the heads to replace the gaskets you probably won't have to reshim.
The tool number is 07979-MJ00000
Ray
88 GL1500
rayworx is offline
post #5 of 31 (permalink) Old 05-18-2009, 11:55 PM
skoto1's Avatar
you didn't say how long you let it run it may clear up on it's own if you let it run a while or that maybe the reason it's been sitting. did you change the oil before you started it up after it sat for that long?
PGR # 190570
cc permit
1988 1500 trike to be
1980 cb900 custom
gl 1988 1500 trike sold
2003 flhtuci sold
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
skoto1 is offline
post #6 of 31 (permalink) Old 05-19-2009, 07:35 AM Thread Starter
The sound is definitely a mechanical sound. I changed the oil before the initial startup - ran it for 30 minutes - changed the oil again (it was BLACK) last night and the carbs finally lined out and was able to idle - which is when I heard the noise. I let it run for about 45 minutes last night and it still didn't line out.
Do I have to pull the head to pump up the HVA or just the cover? I'll pull the cover tonight - let me know if there is anything I can do with just the cover pulled.
post #7 of 31 (permalink) Old 05-19-2009, 08:24 AM Thread Starter
Okay - I've attached a picture of what I think rayworx is talking about. Is there a way to do this without any special tools?
I'm thinking fishing line, spray bottles, sea foamcure-all - the kind of special tools this forum is famous for!
post #8 of 31 (permalink) Old 05-19-2009, 08:45 AM
freetoride's Avatar
You wont have to pull the head.
Neal
"If a job is worth doing... its worth doing over!"
\'90 V-max
\'87 Virago 535 For the wife
freetoride is offline
post #9 of 31 (permalink) Old 05-20-2009, 10:00 AM Thread Starter
Pulled the right cover off last night and inspected #1 and #3 adjusters - they looked fine and were within spec as far as the book showed. Still have the tap/tick sound but not so sure its valve train related. I pulled the plug wires and verified it wasn't arcing - sounds more like an exhaust leak on top of the main casing toward the front. Is there anything in that area that would sound like that? Once it gets above 1200rpm its hard to hear
post #10 of 31 (permalink) Old 05-20-2009, 09:19 PM
Guru
Hatchetman's Avatar
Hold a feather or cigarette around that area & look for signs of air movement caused by an exhaust leak.
Bringing an 84 Aspencade back to life after 20 years Fusionenterprise Goldwing Technical Forum 17 05-15-2015 07:39 PM
Bringing an 83 GL1100A back to life, Sure can use some help Sd455 Goldwing Technical Forum 13 10-29-2011 07:08 PM
In search for headlight and headlight bracket? GL 1100 1981 bringing it back to life! ryster For Sale/Wanted Forum 7 04-04-2010 08:30 PM
bringing an old wing back to life DanGl1100 Goldwing Technical Forum 5 02-25-2010 05:13 PM
Bringing a LTD Back to Life RedWinger Goldwing Technical Forum 29 02-27-2007 07:04 PM
