1996 GL1500 electrical issue - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 06-04-2009, 07:08 PM Thread Starter
Al K's Avatar
This is a re-hash of several other posts.I have no fuelgauge, reverse, running lights or overdrive light, plus several other dash lights.From other posts in the past I went and purchased a new relay R3(10amp blue relay) after checking all fusesto be good. After replacing the relay I have no change.I have a electronics background so I have the meter out looking for 12 volts on each side of the relay. I have 12 volts coming in nothing going out. I used a fiveamp fuse and jumpered across the contacts in the relay box and all the indications are present. Does any one knowwhat to look for or how to check the relay? Only thing I can figure is that I received a bad relay????
Al K is offline
post #2 of 4 (permalink) Old 06-04-2009, 07:44 PM
Check for 12V on the relay coil. The green wire on Relay 3 is ground, the black wire is the 12V supply from fuse #11.I'd check the green wire for continuity to ground and the black wire for 12V. If you don't find 12V on it jump a 12V source to it and see what happens when the relay is forced to energize. If that brings things to life then it's just a matte to trace the 12V wire back through the fuse to it's source.
post #3 of 4 (permalink) Old 06-04-2009, 07:52 PM Thread Starter
Al K's Avatar
Thanks Paul,
I figured it out, My electrical drawing that I had was not correct. R3 is the top row last relay I swapped out second row last relay which was not the correct relay. I currently pulled the pump relay and placed it in that slot while I order a new one. Indications are back.
Thanks
Allen
Al K is offline
post #4 of 4 (permalink) Old 06-05-2009, 12:28 AM
Glad to hear you found it. Try an auto parts store for a replacement relay, these things are pretty much universal.
1998 GL1500 SE electrical issue powersport15 Goldwing Technical Forum 12 05-13-2012 10:39 PM
Electrical issue - GL1500 951Indy Goldwing Technical Forum 3 09-13-2010 04:30 PM
Gl1500 electrical issue PaWinger Goldwing Technical Forum 3 04-17-2009 09:46 PM
Electrical Issue GL1500 Aspencade mdgulick Goldwing Technical Forum 1 04-07-2009 09:42 PM
pdf file service manual (electrical) for 1996 gl1500 se ronnie 3945 Goldwing Technical Forum 14 06-12-2008 11:50 PM
