2006 GL1800 key fob function - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 07-01-2009, 12:21 PM Thread Starter
goab@att.net's Avatar
I have a 2006 wing and the key fob does not work. I changed the battery and still no function. When I push the button, the little red LED lights up, but nothing else happens. Let me know if you have some info. Thanks a bunch
GOAB
post #2 of 5 (permalink) Old 07-01-2009, 12:26 PM
GWEddie's Avatar
It may just need to be programmed again. Instructions in this thread;
https://www.goldwingfacts.com/forums/...462637#p462637
Lucky Eddie.
GWEddie is offline
post #3 of 5 (permalink) Old 07-01-2009, 03:21 PM Thread Starter
Thanks for the info. I tried it and no go. I may have to replace it now.
post #4 of 5 (permalink) Old 07-01-2009, 03:26 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
Welcome from the state of Pennsylvania!
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #5 of 5 (permalink) Old 07-01-2009, 05:49 PM
BenMilner's Avatar
Welcome GOAB. If your remote won't take the code, you will probably need a new one. But sometimes the pickup unit in the trunk can go bad instead, although if the light on your remote is working then its looking like a remote gone bad.
BenMilner is offline
GL1800 Key Fob dadztoy Goldwing Technical Forum 2 06-29-2012 04:26 AM
This I have gotta have, a key fob finder AZgl1800 Miscellaneous Forum 12 03-18-2012 10:29 PM
GL1800 key fob JEFF1 H Goldwing Technical Forum 7 09-14-2011 07:51 PM
key fob from an A4 can it be reprogrammed to work on an A6 bigredarmchair Goldwing Technical Forum 7 05-26-2011 04:19 PM
An alarm system that will work using Honda OEM key fob. MikeW General Motorcycle Discussion Forum 2 06-24-2008 08:26 AM
