1200 Clutch Fluid leak - Steve Saunders Goldwing Forums
post #1 of 9 (permalink) Old 07-02-2009, 11:14 AM Thread Starter
William_86's Avatar
Model: GL1500 Aspencade
My friends 1200 is loosing clutch fluid and has to refill every week, he says he cant spot any leak in the system im telling him it could be leaking inside the engine.
that is possible right?? how hard is to repair a leak like that, you just buy the seal kit?
William_86 is offline
post #2 of 9 (permalink) Old 07-02-2009, 11:24 AM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
Is his crankcase oil getting any fuller?
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #3 of 9 (permalink) Old 07-02-2009, 11:33 AM
rgbeard's Avatar
He'd have to have a lot of clutch fluid change out before he'd notice a difference in the oil level. (5% of 4 qts is 6.4 oz)
Is the clutch getting "soft" or engaging late?
My name is Rusty. I'm an enthusiast of things that ride, drive and fly.
IBA: 63413
rgbeard is offline
post #4 of 9 (permalink) Old 07-02-2009, 05:57 PM
I think that slave cylinder can leak into the engine. However, he'll probably have to replace the unit. I've never heard of a rebuild kit for them.
Smart guys chime in please.
post #5 of 9 (permalink) Old 07-02-2009, 06:05 PM
JOHNO's Avatar
Send a message via AIM to JOHNO Send a message via MSN to JOHNO
the seals in slave cylinder fail same as they do in the master cylinder, you have to search but slave cylinder repair kits are available.
here's the sort of thing your looking for as an example.
http://www.cyclebrakes.com/K&LSlave.pdf(kit number 32-04126 cck-102)
when seal fails the hydraulic fluid will make it's way into the clutch basket and mix with the engine oil. Another possibility is the bleed valve is not sealing, although any leaks should become visible over time.
Johno
1984 GL1200 Aspencade with 1966 Watsonian Palma sidecar
1984 GL1200 Interstate engine out and awaiting waterpump and frame repair
2007 NT700VA Deauville A-B bike
2012 Royal Enfield 500 EFI Bullet (daily ride)
1998 Reliant Robin LX estate (for when it rains)
1992 Reliant Robin saloon (if the other breaks down!)
JOHNO is offline
post #6 of 9 (permalink) Old 07-02-2009, 07:57 PM
Wolfman's Avatar
Model: GL1500SE
Yes, it is possible. It happened to me. The seals in the slave cylinder wear out and fail.
Yes you can fix it. I fixed mine.
The slave cylinder is not very difficult to remove. It's just a tight squeeze to get your hands and your tools in there to remove the bolts.
I did mine when I did my clutch.
I found it gave me a lot more room when I disconnected the entire exhaust system and dropped it down to the ground. It isn't necessary but if you have big hands, it might make a difference.
Jim
Beware, I'm a known thread hijacker.
'96 GL1500 SE
Honda Riders of Tidewater -- Former Chapter President
My personal webpage:
Desert Storm Veteran USS Pensacola (LSD-38)
Wolfman is offline
post #7 of 9 (permalink) Old 07-02-2009, 10:37 PM Thread Starter
William_86's Avatar
Wolfman can you address me to the where you got ur supplies? thanks
post #8 of 9 (permalink) Old 07-03-2009, 07:22 AM
Wolfman's Avatar
Model: GL1500SE
I got mine from the Honda dealer.
On this fiche from Ron Ayers:
http://fiche.ronayers.com/Index.cfm/...p/CLUTCH_COVER
Parts 8,9,7,15 are the ones that are in the slave cylinder thatI replaced.
I also replaced 14 but that required me to take the clutch cover off, so that meansI also needed to replace 3.
Jim
'96 GL1500 SE
Wolfman is offline
post #9 of 9 (permalink) Old 07-04-2009, 10:41 AM
Uncle A's Avatar
There is a weep hole in the slave housing like the one in the water pump. You may find your leak there, running down the rear case. Oil can not get into the engine through here. It will most likely be leaking past item 15 as seen in the fiche from Ron Ayers in the above post.
I installed a "speed bleeder P.N. SB8125L" while replacing these seals. In Canada NAPA P.N. 675-1569 for $16.44 / pair. Well worth it, I struggled without them for quite a while, then went parts shopping. They can also be used for your brakes.
These are metric threads, 8mm x 1.25, but you use a 5/16" wrench ... because they're made in U.S.A.
Uncle A is offline
GL1500 Clutch Fluid Leak Ron Wylie Goldwing Technical Forum 12 03-22-2012 05:37 PM
GL1500 fluid leak around the clutch lever area thumper1963 Goldwing Technical Forum 29 02-22-2012 08:52 PM
Fluid leak from from clutch lever 89 gl1500 eabembroidery Goldwing Technical Forum 5 02-14-2011 04:09 PM
clutch fluid leak around clutch cylinder flange swampfoxcws Goldwing Technical Forum 4 09-30-2008 12:39 PM
gl1200 clutch and brake fluid master cyl leak tlc Goldwing Technical Forum 4 03-18-2005 02:12 AM
