85 LTD carb system removal - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 07-04-2009, 07:02 PM Thread Starter
I am in the middle of removing the engine on my 85 LTD. The air chamber removal process seems like a pain in the rear! Is there any way to simplify this?
Thanks again for all the help!
Charlie
charlied is offline
post #2 of 5 (permalink) Old 07-04-2009, 08:26 PM
Don't remove the carbs, unbolt the intake runners and tie the assembly up to the frame then pull the engine.
post #3 of 5 (permalink) Old 07-04-2009, 10:10 PM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
There are no carbs. The 85 LTD is injected.
busdriver is offline
post #4 of 5 (permalink) Old 07-04-2009, 10:42 PM Thread Starter
Thanks Ill try that. The full teardown of the system according to the manual seemed like a lot of work.
Charlie
charlied is offline
post #5 of 5 (permalink) Old 07-05-2009, 07:30 AM Thread Starter
Sorry to be so slow...........where exactly are the intake runners? Is that where the rubber boots are or right above the heads?
Thanks again for your help!
charlied is offline
GL1100 Carb removal namsgt1946 Goldwing Technical Forum 5 08-13-2012 10:23 AM
1987 Carb removal michttm Goldwing Technical Forum 1 06-30-2010 09:39 PM
Carb removal? Chris07 Goldwing Technical Forum 5 04-10-2007 12:00 PM
carb removal scot Goldwing Technical Forum 14 02-17-2007 03:05 PM
Carb Removal L8ndeb Goldwing Technical Forum 6 09-24-2006 02:05 PM
