84 pulse generator coil replacement or switching to 85 generator.. - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 08-11-2009, 05:09 PM Thread Starter
Is it possible to replace 84 pulse generator coil w/o engine removal? Do coils just die or wobbling shaft destroy them?
One of coils has no continuity.
Thanks.
76, 83, 84I,84A, 86 SEi Wings are gone, now 75, 84A
I have to stop buying dead old Wings...
ignition switch for $8, solenoid for $10, fuel pump for $30 still work fine!
newbiker is offline
post #2 of 4 (permalink) Old 08-11-2009, 05:18 PM
I think it's possible but bring your patience with you. As far as why it failed, age probably played a part in it. A wobbling shaft would ceate other problems such as an oil leak.
When it\'s over your head it\'s under GOD\'S feet.
gotta love the wing is offline
post #3 of 4 (permalink) Old 08-11-2009, 05:38 PM Thread Starter
OK, Clymer says remove engine, Honda says remove swing arm. Who did the job?
newbiker is offline
post #4 of 4 (permalink) Old 08-11-2009, 06:15 PM Thread Starter
Well, lucky me it was wire problem.
newbiker is offline
GL1200 pulse sensor or pulse generator fballfan Goldwing Technical Forum 3 08-14-2012 08:59 AM
Pulse Generator activitytom43 Goldwing Technical Forum 1 02-11-2009 03:06 AM
Pulse Generator rgray Goldwing Technical Forum 6 08-29-2008 10:52 PM
Pulse generator Olegrumpy Goldwing Technical Forum 1 07-28-2008 08:03 PM
pulse generator zimmerleemark Goldwing Technical Forum 9 04-04-2008 01:57 AM
