1983 GL Fork Oil Drain? - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 09-08-2009, 04:30 PM Thread Starter
How much oil does each fork take, is a regular 20w good for two up touring? Any tip regarding changing it.
Thank You.
Oldbro
How do you drain oil from a 1983 GL Interstate fron Forks???
Thank You,
Oldbro
Enjoy everyday as if it is your last day. grin grin ...
Oldbro is offline
post #2 of 6 (permalink) Old 09-08-2009, 05:04 PM
k1w1t1m's Avatar
Year: 2005
Make: GoldWing
Take the air valve out or totally relieve the pressure. Then put a basin under each fork and remove the 10mm drain bolt at the bottom of the fork.
Now I've done it and blown the seal I'd recommend taking the fork caps off at the top. Be careful of the springs. Then work the forks to remove just about all the old oil. Refit the drain bolt. Fill the tubes with oil, I used 8 oz the second time around in each tube. Or fill to 5.5 inches from the top with the forks colapsed.
Alternatively if you elect not to remove the caps you can fill from the drain hole. I used one of those pump oil cans. If you are going to do it this way then add only about 7.2 oz of oil to each fork. There is a risk of over filling this way and a blown seal can be the result.
I used power steering fluid and like the results but then again I don't have much to compare it to either.
Tim
CMA Faith Riders Chapter 732
Don't steal, the government hates competition.
k1w1t1m is offline
post #3 of 6 (permalink) Old 09-08-2009, 08:21 PM
83 models hold 9.8oz of oil each.
20 wt is good, much improvement over ATF or 10 wt.
post #4 of 6 (permalink) Old 09-08-2009, 10:01 PM
scotthohio's Avatar
Better to take the caps off and make sure of the fluid level.
Lots easier than replacing the seals.
Scott
Traveling fork rebuilding and motorcycle delivery available.
Fork seal tutorial
86 GL1200 Aspencade
scotthohio is offline
post #5 of 6 (permalink) Old 09-08-2009, 10:29 PM Thread Starter
Thank You Tim. I will change my oil in the morning. Then we are of and out on the highway for a couple weeks. Weather reports are looking good here in BC and then to YellowStone Park. Your bike looks good too.
Thanks Again.
Oldbro (Terry)
Victoria, BC.
Oldbro is offline
post #6 of 6 (permalink) Old 09-08-2009, 10:41 PM
Hey Oldbro
Aside from checking weather you might want to check Hwy construction in Yellowstone, a few weeks ago they had some sections closed & other areas gravel & mud.
Big Mac, Clancy,MT
Big Mac is offline
GL1100 standard 1983 -Three fork springs inside each fork? Josian Fuste Goldwing Technical Forum 3 01-18-2012 06:59 PM
1994 GL1500SE Front fork oil drain bolt Jim_C Goldwing Technical Forum 11 10-06-2011 06:31 PM
Fork Oil Drain Option GL1500 SaiBeer Goldwing Technical Forum 9 02-22-2011 10:20 AM
GL1500 Fork oil drain bolt 93Wing Goldwing Technical Forum 20 01-10-2010 12:30 PM
Location of fork oil drain plug jsmith24 Goldwing Technical Forum 7 01-31-2005 06:33 PM
