1800 headlite change - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 09-09-2009, 06:33 PM Thread Starter
Wingboomer's Avatar
In a a dire need of instruction on how to change head lamp on friends 01 1800. Is it like a 1500, take off screws behind mirrors and remove front cover. Not much in owners manual. Thanks a bunch. Need info asap.
1998 Honda GL1500 SE
1986 Suzuki Cavalcade LXE
1980 Yamaha 1100 Spec
1980 Yamaha 650 Spec
1973 Yamaha DT-3 250
1970 Suzuki TC-90
Wingboomer is offline
post #2 of 5 (permalink) Old 09-09-2009, 06:36 PM
William_86's Avatar
Model: GL1500 Aspencade
i heard you you needed small hands for that job. maybe in the workshop manual?
William_86 is offline
post #3 of 5 (permalink) Old 09-09-2009, 07:27 PM
Shiny_side_up's Avatar
https://www.goldwingfacts.com/forums/...headlight+1800
You can do a forum search for "headlight 1800" and come up with more.
The service manual says to remove the fairing pocket but I can reach them through the tunnel or fromunderneath. If you or a neighbor have aHonda car made in the last ten yearsor so you can look at the back of the headlamps to better see how the wire retainer thingy works. Handle the bulbs with latex gloves so you don't get skin oils on the glass parts. It is super simple but until you do it once it does seem daunting. PM me if you wantmore.
Shiny_side_up is offline
post #4 of 5 (permalink) Old 09-09-2009, 07:43 PM
Are you changing a complete headlight or a bulb?
post #5 of 5 (permalink) Old 09-09-2009, 11:44 PM Thread Starter
Wingboomer's Avatar
Thanks for the replys. We got it out and new one back in. Not so bad afterall. Thanks again...........
1970 Suzuki TC-90
Headlite change PORKCHOP Goldwing Technical Forum 4 11-05-2010 04:02 AM
headlite question beachbuddy0253 General Motorcycle Discussion Forum 7 10-25-2008 09:18 PM
GL 1800 Coolant Change 2goldwings Goldwing Technical Forum 18 01-03-2008 05:37 PM
1800 oil change erxkeel Goldwing Technical Forum 12 06-09-2007 10:09 PM
headlite protector cyclepath General Motorcycle Discussion Forum 6 01-20-2007 05:29 PM
