Midrange Acceleration issues GL1100 - Steve Saunders Goldwing Forums
post #1 of 20 (permalink) Old 10-12-2009, 04:51 PM Thread Starter
Peterbylt's Avatar
My 81 1100 has been having issues accelerating in the midrange. It would idle smooth and run at high RPM pretty good but when you cranked on the throttle around 3500 to 4500 rpms it would sputter and complain and eventually smooth at a higher RPM.
I took the carbs apart (again) and cleaned them but could not find any issues, I suspected a sticking CV slide but did not find that to be the case. I reassembled the carbs reset the sync, the sync was very close, but no change in the performance.
Finally I pulled the hose off for the ignition advance and could not feel any vacuum. I used some carb cleaner and a small wire and found the port to be clogged the opening inside is much smaller than the hose nipple and I had to poke around some before the wire went in the hole and poked the clog out.
After cleaning and making sure there was vacuum, I checked to make sure the advance unit was working and put the hose back on.
When I did my test ride it accelerated smoothly all the way through the range and accelerates better than I can remember.
I hope this helps out anyone else having the same issue.
Peter
75 GL1000
81 GL1100
85 GL1200A
75 550F
Peterbylt is offline
post #2 of 20 (permalink) Old 10-12-2009, 10:47 PM
Yep, I had a similar problem on an '82 Aspy. It wasn't the vacuum advance on that one but the centrifugal advance was frozen. The two different advance systems work for different purposes on these bikes, the vacuum advance shifts the timing to adjust for quick throttle changes while the centrifugal advance adjusts for the rpm range the engine is running.
post #3 of 20 (permalink) Old 10-12-2009, 11:05 PM
Peterbylt,
Thanks for that post. I just added it to the index.
post #4 of 20 (permalink) Old 10-12-2009, 11:10 PM
JBz
JBz's Avatar
exavid wrote:
centrifugal advance was frozen. the centrifugal advance adjusts for the rpm range the engine is running.
Was bad fuel mileage a sympthom. ???I imagine it started fine.Was it just doggy or did it pop backthrough the carbs. JB
JBz is offline
post #5 of 20 (permalink) Old 11-25-2010, 10:57 PM
littlebeaver's Avatar
Model: 1981 Goldwing 1100 I
Thank's Peterbylt I checked mine and it was clogged also, the bike accelerates much better now, it's still sloppy until warm though, I'm trying to figure out where this centrifugal advance is located? How do I unfreezeit..?
1981 Honda Goldwing 1100 Interstate
littlebeaver is offline
post #6 of 20 (permalink) Old 11-25-2010, 11:00 PM
Can you tell me how to fix this centrifugal advance thingy, I am not quite understanding what this is and or where it is? thanks in advance..
post #7 of 20 (permalink) Old 11-25-2010, 11:57 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
littlebeaver,
The post was written a year ago, you might get a faster response if you PM'd peterbylt. He is offline as you can see in the posting info.
Im not sure if he meant the spark advancer in the vacum advancer on the back of the engine or not. Those work together for spark advance. You might also get some better preformance by checking your spark plug gap and setting it to the lowest gap in the specs. I don't know which year is your 1100, so look it up and set to lowest size ie; 82-83 plug gap range .031-.035 would be set to .031. No matter what gap you set it to, be sure and do a plug color test to see how it is preforming.
#3 is the spark advance in theparts fiche, ithas slots that need to be rust free and oiled/ lightly moly greased to slide properly.
http://www.teamecc.com/fiche_section...&fveh=3435
I no longer have a repair manual for the 1100 to see if I could find it in there. That is the only mechanical advancer I know of on the 1100.
Hope it helps.
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #8 of 20 (permalink) Old 11-26-2010, 12:02 AM
thanks a million, Newday 777...littlebeaver
post #9 of 20 (permalink) Old 11-26-2010, 12:22 AM
Still Learning
newday777's Avatar
ride on bro
Stu
Previous bikes
post #10 of 20 (permalink) Old 11-26-2010, 09:30 AM
2manywings's Avatar
Model: 2004 GL1800
Thanks for the insight guys.I've got an'80 gl1100 that has been running sluggish and I am pulling the engine to do clutch and stator work. So I will be checking and cleaning this too.
This is a GREAT site. THANK YOU to all that contribute!
76 GL1000/ 48,000 miles-Sulfur Yellow
76 GL1000LTD
84 GL1200 (LTD Clone)
85 LTD w/ PoorBoy conversion
98 GL1500SE
2004 GL1800 (double darkside)daily driver
2007 GL1800
and several doner bikes.
The numbers are ever-changing
2manywings is offline
Acceleration Problems - 83 GL1100 Aspencade bfrawley Goldwing Technical Forum 5 08-06-2012 05:01 PM
GL1100 Acceleration whining niose mrclean Goldwing Technical Forum 3 07-09-2012 04:46 AM
GL1100 a little boggy in the midrange Cyclebuster Goldwing Technical Forum 4 04-19-2012 09:26 AM
Think I found the issues with the tired midrange on my GL1000, but? tribologist Goldwing Technical Forum 14 04-13-2012 12:23 AM
gl1100 sluggish acceleration Jason m Goldwing Technical Forum 37 09-06-2008 06:41 PM
