89 GL1500 Gas cap - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 10-14-2009, 12:46 PM Thread Starter
Just got this bike and it did not have the original gas cap, so ordered one from a cycle salvage place. The one I got does not have a place for the vent/overflo line. Does it matter at all to me?
Thanks for any help
Larry
ogre56 is offline
post #2 of 8 (permalink) Old 10-14-2009, 02:04 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
There's no vent line on the cap ...
Here's a foto of some other stuff (cap near center bottom) no hose or vent or anything -- the plastic perimeter piece is just a lanyard to keep the cap from wandering off during fills.
satan is offline
post #3 of 8 (permalink) Old 10-14-2009, 03:29 PM Thread Starter
Mine has an original line to go to the cap - the same way as my brothers does. His has a line running up to the gas cap. Both of these are 89 GL1500s.
Larry
ogre56 is offline
post #4 of 8 (permalink) Old 10-15-2009, 08:47 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Damn... My bad.
Is your bike originally a California Emissions model?
The "all others" cap (HONDA 17670-MN5-003) is what that photo shows...
I've not worked on a CA model, but they have the hose you're speaking of (cap = Honda 17670-MN5-741).
Be prepared for the sting, that cap is prolly 3 or 4 times the price of the standard cap.
Goes to show, I sohoulda looked it up before popping-off the quick answer (does your air filter have the embedded charcoal element?)
satan is offline
post #5 of 8 (permalink) Old 10-15-2009, 01:40 PM
northwing's Avatar
Hi, I've got an 88 1500 with the same cap as yours and the pipe (circled in yellow) going nowhere. Do I understand from what your saying, the cap should have a pipe coming off it connected to the copper pipe? I've run my bike for 4 years like this and do occasionally smell petrol. I assume it's from this pipe.
Thanks, Jim
1988 Gl1500
If you see a vehicle with a indicator on, the bulb works, if it flashes the relay works, if they turn......they know it\'s on!!!
northwing is offline
post #6 of 8 (permalink) Old 10-15-2009, 03:46 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Oh no .. that circled "end" of the vent is just a vent to atmosphere for the carbs -- no connection...
The photo was stolen from another thread and intended only to illustrate the HONDA 17670-MN5-003 fuel cap.
My '88 is the same as yours northwing , it's got that incomplete and open vent pipe screwed to the rear of the airbox like thousands of others...
satan is offline
post #7 of 8 (permalink) Old 10-15-2009, 09:51 PM
Ogrebro's Avatar
Model: 80 GL1100, 08 GL1800
My 89 has the same hose and vent line. I don't know if mine or Larrys is a California model. How do we tell if they are? Will it hurt anything if that vent line is left open?
Bill
Ogrebro is offline
post #8 of 8 (permalink) Old 10-16-2009, 12:02 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
To identify the emissions package on the bike there are a couple of 'flags' and one dead giveaway.
- The fuel cap with a hose is part of an extended evaporative emissions control system not (generally) found on the 49-state bikes.
- There will be a vacuum hose routing diagram on the fuel tank (lthat'd be under the front of the seat) for CA models (I've seen a few of the diagrams, but I believe that they're for CA only in 88-89)
- There is an additional charcoal element that is screwed into the air filter taking roughly 1/4 of the available filter space (left rear corner area of the filter is where the charcoal element is fastened) - usually NOT installed if someone priced the CA-only air filters
- The Dead-Giveaway would be to look at the emissions label (a "Vehicle Emissions Control Information Label" is required for all US models) that'll be affixed to the right side of the frame usually at the front edge of the space covered by the battery cover. The label would indicate if the bike was certified to the US emissions or to California emissions
If it all comes down to being unknown still, you could have a dealer run your VIN, Frame, or Engine's number (VIN probably best) to see what market it was built for.
If memory serves me correctly, the CA models also have a carbon canister that is plumbed to collect these evaporative emissions as in - line to the fuel cap, line to that funny metal pipe (the cab float bowl vents) and probably one to the air filter box. The intent of that canister is to use a weak vacuum in the canister to "draw" HC emissions from the connected systems into the carbon media in the canister, then on the bike's next start allow the stored HC vapors to be drawn into the engine's intake for combustion/conversion into some other pollutant (heat, noise, power, etc)
As for leaving the hoses disconnected being a "trouble" for the bike... I don't believe that it would have major impacts, HOWEVER... The calibration of the computer and jetting should address the flow of gasses that will be entering from the evaporative canister (ok really ought'a, but I have none of the running code for the computers or specs on CA-specific carb changes). I'd suspect that on the grand scheme of things, I'd suspect that as long as you do not un-cap any vacuum source you'd be OK (the canister 'prolly has a temperature or vacuum-level sensitive control on however it's routed back to the intakes)...
That said, I'm blaming the disappearing polar ice shelf on you two guys :P
satan is offline
Fuel around GL1500 gas cap/tray road_rascal Goldwing Technical Forum 7 11-23-2011 03:00 PM
GL1500 Radiator Cap Question Looking for a 4 to 7lb Pressure Cap Mr. Fix it General Motorcycle Discussion Forum 3 06-11-2011 09:37 PM
That hose that hooks up to the GL1500 gas cap Fritz_The_Cat Goldwing Technical Forum 9 11-10-2010 11:09 AM
GL1500 gas cap vent tube furnacedoc Goldwing Technical Forum 2 06-26-2010 05:08 PM
Gas leak by gas cap longislandguy Goldwing Technical Forum 1 03-21-2010 08:13 PM
