GEAR POSITION INDICATOR - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 01-11-2010, 01:00 PM Thread Starter
SARGE3056's Avatar
Model: 2009 GL 1800 AIRBAG
Send a message via Yahoo to SARGE3056
Is there a digital indicator/readout (other than the 'Reverse' and 'Neutral' indicator Lights) on the 2006-2009 GL1800's (similar to the one on the 85 GL1200 'Limited Edition') that shows what gear you are in?
If not, are there 'after-market' ones available and, if so, WHERE?
Thanks!
Greg Jones
Cambridge, Ontario
Canada
Amicus Semper Fidelis
SARGE3056 is offline
post #2 of 4 (permalink) Old 01-11-2010, 01:18 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
DBohrer is offline
post #3 of 4 (permalink) Old 01-11-2010, 03:40 PM
Senior Guru
agnogel's Avatar
http://www.cyclemaxohio.com/inc/sdetail/40971
Peter
agnogel is offline
post #4 of 4 (permalink) Old 01-11-2010, 11:29 PM
When I first got my 1500 after having an '86SEi I really missed the gear indicator and was thinking of adding one. After a couple months riding the 1500 I discovered I really didn't need one. It doesn't take long before you notice the relationship of the tach and speedo needles. On the 1500 when in fifth gear the tach needle points lower on the scale than the speedo at any speed. In fourth gear the two needles are almost parallel and in third the tach needle is higher than the speedometer on the scale. In second the tach is about twice as high as the speedo. In first gear you know where you are due to the high revs. The only thing the indicator would be good for is to prevent you from stopping in a higher gear and stalling when the light goes green. You don't need an indicator for that, do it a couple times and you won't forget again due to the embarrassment.
Gear position indicator on 87 GL1200A swjones214 Goldwing Technical Forum 17 04-09-2015 12:27 PM
Gear position Indicator GL1500 Haroldmac Goldwing Technical Forum 2 07-11-2012 06:25 PM
Gear position indicator the Rovin Rev. Goldwing Technical Forum 2 04-29-2012 03:49 PM
Gear Position Indicator SARGE3056 Feedback for Hondas Goldwing Team 25 04-10-2012 02:17 PM
Volt/gear position indicator jimbojive Goldwing Technical Forum 9 01-13-2007 09:36 AM
