popping through the carbs - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 01-23-2010, 09:03 PM Thread Starter
Hi everyone. i have a 1986 goldwing aspencade with 59k miles, i am getting a poping through the carbs, the plgs are new, and are burning perfectly, compression is at 170 lbs i am sure it is running lean. i am going to change all vacuum hoses, and thinking also about the air shutoff valve. when i hook my vacuum gauges to sync the carbs the gauges go totally crazy, i rev it up to about 2900 rpm and the gauges settle down, i know this is not normal, anyone have this problem before or any ideas,,thanks for all your help
Bill
frenchy1234 is offline
post #2 of 10 (permalink) Old 01-23-2010, 09:17 PM
litfuse's Avatar
Model: GL1100I
Air shut off valves or a couple of plug wires crossed.
Welcome to the forum!
litfuse is offline
post #3 of 10 (permalink) Old 01-23-2010, 09:35 PM
Take a look at the diaphragms on the slides. You may have a leak there.
post #4 of 10 (permalink) Old 01-23-2010, 09:44 PM
skoto1's Avatar
welcome aboard frenchy what did you do before it started poping or did it just start on it's own?
PGR # 190570
cc permit
1988 1500 trike to be
1980 cb900 custom
gl 1988 1500 trike sold
2003 flhtuci sold
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
skoto1 is offline
post #5 of 10 (permalink) Old 01-24-2010, 08:00 AM Thread Starter
the bike ran perfectly, last summer i rode from flordia to upstate new york without any problems, this is something that has just started, i have no crossed plug wires, have read all i can find online about this, and many seem to think it is the air cutoff valve. if that was bad would it make my vacuum gauges go crazy at idle? i am sure it has never been changed, i will change this valve and all vacuum hoses, and taking the plugs out they all are burning alike and thats a tan color, my manual does not say anything about this so i am hoping to hear from some of you that may have had this same issue,,again thanks for all your replies.when i get this cured i will post the problems.
post #6 of 10 (permalink) Old 01-24-2010, 11:56 AM
Uncle A's Avatar
What type of vacuum gauges are you using? Have you used this same set of gauges on this bike before without the needles fluctuating at idle?
As you know, the vacuum to each carb changes / pulses at idle, unlike on say, a car engine where there is a steady vacuum at the carb base.
Uncle A is offline
post #7 of 10 (permalink) Old 01-24-2010, 01:13 PM Thread Starter
yea, i have used these before, i even put them on mu buddies 1500 and they were seady at an idle, i tried them on the other carbs and all were the same, bring the rpm up to say 2900 they clear up.
post #8 of 10 (permalink) Old 01-24-2010, 02:09 PM
Have you checked the timing?
CaptainMidnight85 is offline
post #9 of 10 (permalink) Old 01-24-2010, 04:28 PM
In still think it's one of the diaphragms. Did you check them?
It doesn't take much of a pinhole or crack to make them not hold constant vacuum.
post #10 of 10 (permalink) Old 01-24-2010, 08:03 PM
If the popping occurs at times other than decelerating it's not the air cut off valve. That only comes in to play when the throttle is closed and the vacuum goes high in deceleration.
85 GL 1200 Aspy carbs popping when cold freddyboy Goldwing Technical Forum 6 06-13-2010 06:40 AM
GL1200 popping in the carbs frenchy1234 Goldwing Technical Forum 2 01-30-2010 02:51 PM
1984 aspencade popping in carbs dgscarnut Goldwing Technical Forum 9 12-07-2008 12:05 PM
popping threw the carbs. longhaireddwb Goldwing Technical Forum 8 06-10-2006 03:13 PM
Popping/backfire mag Goldwing Technical Forum 11 10-20-2005 08:18 PM
