1500 final drive - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 01-28-2010, 04:58 PM Thread Starter
I am replacing the final drive on my '96 with one from a low mileage 2000. I have the final drive off but I can't get the drive shaft out of it .what am I doing wrong?
dakotawings is offline
post #2 of 7 (permalink) Old 01-28-2010, 05:36 PM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
It isn't unusual for the shaft to have some rust and get stuck. It will come away with a bit of effort.
Put the shaft in a vice and tap the drive unit with a mallet to loosen it up.
GWNorman is offline
post #3 of 7 (permalink) Old 01-28-2010, 05:56 PM
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
During assembly at the factory the final drive and the drive shaft hang from an assembly line and moved towards the partially completed motorcycle until the final drive was required to be installed.
The shaft is held onto the final drive with a large clip. Tapping or beating on the shaft won't release it from the final drive.Rust has nothing to do with it.
Hold the final drive in a vice (use some wood on the vice to keep from marking the final drive)
Position the shaft so it is parallel with the ground. Rotate the shaft in a circular motion while pulling out at the same time. It takes a little 'technique' but it will come off.
DISCARE THE CLIP AFTER THE SHAFT IS REMOVED. The clip is only there to hold the shaft onto the final drive during factory assembly.
Hope this helps.
Ray Wooldridge
Ray
88 GL1500
rayworx is offline
post #4 of 7 (permalink) Old 01-28-2010, 06:51 PM
wingnut's Avatar
Send a message via Skype™ to wingnut
Well spotted Ray.
Steve Saunders,
Founder Member & Admin.
wingnut is offline
post #5 of 7 (permalink) Old 01-28-2010, 09:51 PM Thread Starter
thanks rayworx,i will give that a try tommorrow
post #6 of 7 (permalink) Old 01-29-2010, 11:58 AM
grambo's Avatar
if you have a 2k rear end with shaft together use the 2k shaft too..just pack it(grease) and leave it...if its better than yours...just takes some figin to get it in the front u-joint...or is this your plan already?
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #7 of 7 (permalink) Old 01-29-2010, 05:20 PM
Older and Wiser
BenMC's Avatar
Model: GL1500 Aspencade
I found the shaft was easy to slide into the u-joint, but I had the Wing up on a Pit Bull lift and was able to sit on the ground and ease it in.
Ben.
BenMC is offline
1500 final drive boot The Fonz Goldwing Technical Forum 5 03-26-2012 11:25 PM
1500 Final drive galaxyhunter Goldwing Technical Forum 9 06-11-2011 10:47 PM
1500 final drive elvisskan Goldwing Technical Forum 1 04-17-2010 04:56 PM
I need a 1500 final drive . . . . . . quickly. Wingnumberone For Sale/Wanted Forum 7 06-07-2009 09:24 PM
1500 final drive oil Hickey Goldwing Technical Forum 8 04-24-2008 10:27 AM
